Question about Car Audio & Video
97 nissan altima
Oil reading measures up to the bend in the dipstick,is this overfilled?
    New Friend:
  • 101 Answers
Is the engine hot when taking reading? is the motor running?when checking oil level the engine has to be off and cool.if not you get an in accurate reading.if still over line on dipstick,then yes it is overfilled
Posted on Jan 22, 2008
01 honda crv dipstick tube is upside down
the tube is only so long and will not change the amount of oil unless it is really big on one end versus the other .
Feb 11, 2017 | 2001 Honda CR-V
How many quarts of oil and what type of oil does a 1996 nissan altima take
4-5 quarts of 5w30, on average. It will depend on motor size...A v-6 uses more oil than a v-4. When in doubt, put 3.5 quarts in, then start measuring with the dipstick to avoid over-filling with oil, as this can blow a gasket, worst case scenario... 5W 30 Synthetic Oil Bing images
May 27, 2016 | Nissan Cars & Trucks
How many inches is oil dip stick for nissan altima 3.5 ltr V6
How you check your oil level properly on a Nissan 3.5 engine
? 1:15
https://www.youtube.com/watch?v=5uih27KiKMo
Mar 2, 2013 - Uploaded by FixyourNissan
When you have no dipstick tube you can incorrectly check youroil level. ... How you check your oil level ...Missing: inches ‎ltr
Oil Dip Stick Reading...Help! - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../92792-oil-dip-stick-reading-help....
Mar 28, 2003 - 14 posts - ‎12 authors
Okay, I have heard that the dip stick is a little wierd. ... I've had no problems checking the oil level in many cars over the years, but the alti really ... Oil Change, dipstick reads above high
May 26, 2012
4.5 or 5 quarts of oil?
Nov 4, 2009
2005 Altima 3.5 liter tranmission fluid change
Sep 1, 2008
Checking the engine oil - w/ warm or cold engine?
May 30, 2007
More results from www.nissanclub.com
Check Oil Level 2002-2006 Nissan Altima - CarCareKiosk
Dec 13, 2015 | Nissan Cars & Trucks
Rest oil life on a 2002 nissan altima
Please change your oil at least twice a year whether it needs it or not. Also, top it up when it gets low on the dipstick. rest-oil-life-2002-nissan-altima-l0u5xrrbjmm23votbgnhzwek-3-0.jpg
Jan 11, 2015 | 2002 Nissan Altima
OIL IS SHOOTING OUT OF THE DIPSTICK FROM THE OIL PAN.
Click here to see.http://www.autozone.com/autozone/parts/AZ-Filters-PCV-Valve/2003-Nissan-Datsun-Altima/_/N-jklw9Z8gd7h?itemIdentifier=926641_0_0_
Nov 11, 2012 | 2003 Nissan Altima
Where do i add transmission fluid
Under the hood, look for a dipstick toward the rear of the engine, the dipstick for transmittion is usually red. Once you pull the dipstick, you add the fluid in that cavity. make sure you dont overfill it, so just add small amounts at a time.
Mar 23, 2012 | 2001 Nissan Altima
Want to know how to do a full fluid change on a 2005 altima's transmission
If your vehicle has the CVT for the transmission, you must use the proper fluid first off. (Nissan NS-2)
There should be a drain plug on the transmission. These transmissions dont have a cooler lline that runs through the radiator to cool the fluid like older vehicle, some of them have a cooler built into the transaxle assembly that actually has coolant running through it. Below i have included a list of the various transmissions used in this vehicle, be sure to use the proper fluid or this will ruin the transmission very quickly and will void any warranty (if still available). You can also check the handle on the transmission dipstick, there should be a label stating which fluid to use.
*Note: Do Not Overfill the fluid, any slight overfill will cause poor operation of the transmission. If there is a way for you to measure how much you drain out, i would strongly recommend doing so, and be sure to put that same amount back in, as to reduce the chance of overfilling.
Hope this helps...
Sep 16, 2011 | 2005 Nissan Altima
I changed my ,02 roadkings trans. fluid --only 16oz drained out --i had the bike level--put 20oz back in --no reading on dipstick--do you check oil with bike level or on stand--also do you measure level...
Check the level of the transmission lube with the bike standing straight up. The transmission holds between 20 and 24 ounces of oil. I always put 24 ounces in them. It should check on the dipstick without the dipstick screwed in. Do not overfill.
Good Luck
Steve
Aug 02, 2011 | 2005 Harley Davidson FLHR - FLHRI Road...
97 altima
normally you got 2 line on the dipstick the bend is pretty low if i remenber put oil to the last line going up if you ask the guy at the gaz pump be carefull they dont always no go see a mecanic dont be affraid to ask cheers
Jan 12, 2008 | Car Audio & Video
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
