Question about Estate EED4300SQ Dryer
Hook up What type of screws do I need to hook up the 4wire cord to the back of my dryer?
    Genius:
  • 2,920 Answers
You need to use the same ones that came off of it.if you dont have them contact an appliance repair shop and ask to buy them they will have what you need
Posted on Aug 20, 2008
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
I need to place a new pony tail on the back of my dryer, I do not know what screws to hook them up to?
IF YOUR TALKING ABOUT THE POWER CORD THE MIDLE SCREW IS FOR THE COMMON WIRE THE OUTSIDE SCREWS ARE FOR POWER, THERE SHOULD BE TWO SOLID COLER WIRES THAT CONNECT ON THE OUTER SIDE, THE OTHER IS FOR THE MIDDLE
May 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I don't know what the three posts in my old dryer is, as far as whats going to match the 4wire cord i got
look in the back of the dryer,around half way up in the middle you'll see the block where the cord connects too,you''l see three screws or posts there,the white wire which is the neutral goes in the middle,the red connects to one of the outside post or screw and the black goes to the other side doesn't matter what side,now you have the green wire left,that's the ground wire,just ground it anywhere in the back as long as it touches the frame,that's the only difference is the ground from the three prong cord,you can remove any screw in the back stick the ground on the screw and screw it back into the frame and you're done,good luck
Mar 11, 2010 | Hotpoint NVL333EY Electric Dryer
Eletric cord installation
The supply cord on a dryer can be 3 wire or 4 wire, depending on the existing receptacle. All new construction must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three terminals. The outside terminals are for connecting the outside wires of the cord. In a 4wire hook up, the center terminal is for the center, insulated, white wire, the neutral. The bare copper or green wire of the 4wire cord gets connected above these terminals to a lug or stud on the body of the dryer. There may be a strap there. For a 4wire cord connection this strap is connected to the stud only.
The change for a 3wire connection is that the center green wire of the 3wire cord connects to the center of the three power terminals along with the grounding strap from the dryer body above.
Dec 05, 2009 | KitchenAid KEHS01P Electric Dryer
We have moved and the three prong cord now needs to be four prong
Ok here is how to hook up looking at dryer. Left brass screw is hot put red or black wire on. Center screw silver is neutral put white wire on. Right brass is also hot put the red or black wire on which one you have left. The green you ground to the dryer body or you can put with the white wire.
The reason why you have to hot wires is that it is a 240 volt dryer. Each hot wire caries 120 volts. The hot wires are the red and black. The white is a neutral witch is also a ground
I hope this helps. If you have any questions please ask before you rate.
Good Luck And Thank You for the post
Oct 20, 2009 | Dryers
How do i hook up my dryer from a 3 prong to a 4 prong
UNPLUG DRYER FIRST.
Remove old cord from back of dryer. Make note of where white, back and red wire hook to on piece of paper.
New cord has 4 wires. looking at the back of dryer,
RED Wire, should have been tied to terminal screw on right side,
WHITE Wire, should have been tied to center terminal,
BLACK Wire, should have been tied to left terminal,
Remaining wire is GREEN, attach to body ground screw located next to cover plate, screw is generally painted green. IF not attach to unit body.
Oct 01, 2009 | GE DCVH515EFWW Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryer cord access
not sure why you wouldbe able to remove the one cord and having an issue connecting the other.
perhaps the old cord had like a y(open end) connectoin point and the new cord has eyelets(closed end)??? if thats the case and the y connectoin was behind hte terminal block( or sandwiched between) by removing the terminal block screw you can mount hte new infront of block, secured by main screw.
Mar 25, 2008 | Dryers
Estate EED4300SQ Dryer Logo
32 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
