Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Canon Ixus Spares
Hi does anyone out there know where I can get Canon Ixus 30 spare parts, I have a broken ribbon cable and it would be a shme to scrap it just for that Thanks in advance. Paul
lloydy1970@googlemail.com
    Scholar:
  • 99 Answers
Www.ebay.com
Posted on Feb 08, 2008
The screen is broken no take pitchure
Remove the battery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Apr 01, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Cannon IXUS 500 purple fuzzy lines in view finder and pictures
Yes it's a very common problem for your model camera. This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 30, 2009 | Canon PowerShot S500 IXUS 500 Digital...
How do I change the LCD screen please?
Very easy.
Remove the batery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Sep 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Black screen can not take pictures caant even view them
hi..
I had the same problem. The flex cable for backlight was broken. I take out the backlight LED module. There have one resister along with 4 LED. I soldered two wires (AWG 30) onto two sides of resistor. Just follow the trace of flex cable and then solder the wires to the pins of connector directly. Although there have 4 wire on the backlight cable, it only need two to work. In order to avoid any finger print and dust fall on to the LCD, it would better wear a hat and plastic glove during this operation.
thank u
rate me!!
Aug 23, 2009 | Canon PowerShot SD100 / IXUS II Digital...
FZ-30 LCD flat ribbon cable broken
Part No is VYQ3473. You can order it directly from Panasonic. It will cost you 29 USD without taxes.
Jimi
Nov 19, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Canon ixus i7. LCD screen is cracked, and thus does not sdisplay any image, however the camera still zooms, takes pictures, etc Obviously now viewfinder so only way to see what your taking pic of is...
I know some canon LCDs can be replaced by the user. Canon will sell you the specific part or you can find them on ebay. The LCD ribbon cable can be easily pulled out and with a little fiddling a new one can be put in. I have not personally done it with at ixus i7. When I did it it cost like $45. Goodluck!
here are some photos of the process for a canon SD. I know the i7 might be a little different.
canon lcd replacement images.
Jul 12, 2008 | Cameras
Overexposed pictures and white horizontal lines
I also having this problem white horizontal lines ...any solution?
If repair how much around?Please help!
Aug 12, 2007 | Canon PowerShot SD20 / IXUS i5 Digital...
Anyone want spare parts for Canon S40?
Hi BigLarry, My toddler daughter recently dropped our Canon S40, and broke the casing on the camera. It still works, but doesn't retract the lens when using the slide cover. I need to replace the casing. If you still have the unit, would you be interested in selling it to me for spares? Is the casing still in good order? If so, I will bear all costs of postage too Hope to hear from you soon Regards Simon L
Jan 11, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon digital camera ixus 65
Go to the Canon web site and download the English version to your PC.
Jan 05, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
