Question about Iomega (33090) 250 GB Hard Drive
250 GB IOMEGA HAD
The drive wont read when plugged in VIA USB port. It also wont even display under computer mangement. Its like it dies. it POWERS UP but doesnt come up. I have restarted, changed USB cables powered down the exeternal HD and nothing.
  • 1 more comment
  • BIG-N1 Jan 12, 2008
    Well all was well and I Defragged it the other day, It started making a funny whining sound after Defragging. It sounds if its running but again a Louder than normal whining but also sounds as if its running slowly, if at all.
    Thanks
  • Anonymous Jun 24, 2008
    my ext harddrive worked well but when now connected my computer is unable to recognize it .A message comes up saying it has malfunctioned
  • sht2v Jul 11, 2008
    I have the same problem. Powers on fine, but once plugged in with USB makes some weird noises and isn't recognized by my computer.
    Problem Solver:
  • 7 Answers
Can you tell if the drive is spinning? I have a USB HDD, and it sticks sometimes, a good whack on the case usually gets it to spin, but that's not in the best interest of the drive, so I wouldn't recommend it...
Posted on Jan 12, 2008
    Problem Solver:
  • 4 Answers
Does it display in device manager as a non recognized device? You may have to find it in the registry and delete and keys relevant to the drive.
Have a look in Key Local machine, Sys, Control set 001, Class
My iomega external hdd has its lights on but cant be detected and does not seem to read anymore
i had the same problem. you have to be patient. open my computer through the start menu. unplug the hdd wait 15 secs and plug back in. if it still doesnt read try another port. and if it still doesnt work your hdd has a malfunction and you may need a new one
Feb 01, 2011 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
Have only just decided to install my new Iomega 500 GB usb 2.0 hard drive and I have mislaid my quick install guide. I have an Apple imac can you help please
Just connect the AC power to the IOMEGA, and the USB cable between the IOMEGA and a USB port on your computer. It is a "plug-and-play" device, and so Apple OS X should automatically recognize it.
Nov 21, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
I have tried connecting my Iomega 250 gb USB 2 Hard Drive to my computer and it is telling me that the unit has malfunctioned. Is there any way of getting the data off it?
First try connecting this USB drive to a different computer.
If this did not work then the USB adapter case is faulty, then remove the hard drive from the case and attach the hard drive to an USB hard drive adapter then plug it into a working computer's US port. If the hard drive is OK then the computer will see this as an external storage device and you can open the folders and files to backup the data off this hard drive.
If this does not work then there are companies that can recovery data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 21, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
My iomega 500gb external hd isn't being recognized. There's an icon for safely removing hardware but under the 'my computer' tab there's no icon for the drive, as though its not even there. It had been...
Did you have to install a driver for it initially? Try reinstalling the driver, if so.
I thought most drives were plug and play. If it does not have a driver, trying using a different USB port. Sometimes the ports can freak out and not recognize the item plugged in, especially if you use multiple items in the same port. (ie, cameras, cell phones, printers, etc)
Hope this helps at least some. Good luck!
Jul 31, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Have a WD 250 GB and wont connect to Computer
It is the cable. Use an original western digital usb cable for this drive.
Mar 31, 2009 | Western Digital Passport WDXML800UE...
Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
Plugged in my iomega hard drive and not connecting to computer ?
Make sure you don't plug it into a USB hub. Some USB ports on computers can go bad from time to time. See if you can switch it.
If that doesn't work go to the control panel of your computer. Go to administrative tools. Go to computer management. Go to storage and select disk management. Make sure you see that partition for you hard drive. Format it to NTFS if you have to.
Aug 15, 2008 | Iomega (33090) 250 GB Hard Drive
Failure to mount on desktop
Iomega which is now a thing of the past were renowned for their fragility It may well have died
May 23, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
132 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
