Question about Admiral AW22 Top Load Washer
Washer not spining out
In both the rinse cycle and the final rinse
  • Anonymous Oct 14, 2008
    washing machine full of water and does not engage
    Problem Solver:
  • 19 Answers
WITH MACHINE SET ON SPIN CYCLE, DEPRESS LID SWITCH. DOES IT PUMP OUT? DOES IT SEEM TO BE LOCKED UP AND DO NOTHING? CAN YOU ASSIST IT BY HAND AND IT TURNS? IF YOU CAN MAKE IT TURN WITH HELP,YOUR BELT IS PROBLY WARN. IF MOTOR RUNS AND YOU CAN'T SEEM TO GET IT TO TURN WITH HELP YOUR SUPORT BEARING FOR INTER TUB IS LIKELY STUCK AND BAD.MAJOR SERGERY REQUIRED.COST APPROX. 150.TO 200.00 TO FIX. THANK YOU HOPE I HELPED. FXIT
Posted on Jan 30, 2008
6ya staff
SOURCE:
Prem Mulberry
  • 94 Answers
SOURCE: Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Posted on Oct 17, 2007
Anonymous
  • 85 Answers
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 18, 2009
ned_san_jose
Ned Halaweh
  • 234 Answers
SOURCE: Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Posted on Jul 07, 2009
Anonymous
SOURCE: This is a washer whirpool mod:lsw9245eqo and ser
I don't know what is the solution repair
Posted on Jan 22, 2010
archaeology
Archaeology
  • 662 Answers
SOURCE: My GE wjre5550h1ww waher makes
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Posted on Dec 11, 2010
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washer is full of water but will not spin
if your washer has old dial selector ,does it continues and finishes "cycle" without spining or does the selector stops moving also you could have a bad timer ,newer ones will have some sort of electronic module
Feb 23, 2012 | Kenmore Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Whirlpool Washer Stop Working after Agitate
Good day,
If it goes thru the wash cycle normally then quits, it is the lid switch assembly.
To remove the top console, be aware there are 3 locations for the screws. Bottom left and right. Bottom left and right but covered by plastic end caps that have to be unsnapped, and finally, bottom rear.
There are also 3 different lid switch styles, so use the complete model number or take the old one in to the supply house.
Here is a good tutorial on the change out procedure.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 05, 2010 | Whirlpool Washing Machines
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Oct 17, 2007 | Maytag Performa PAV2200
Admiral AW22 Top Load Washer Logo
148 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
