Question about Nokia 6600
Regarding the connection
The select access point window appears automatically after few sec and i have to close it again and again how can i deactivate this window.
Unlock pone
Posted on Jan 12, 2008
Pasword
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
Pleas help me , i can't connect to router becuose cant have ip gatewy i connect by ethernet to router bout cant access to it.
Router's default IP is usually written on its case, check user manual as well.
If you did not change anything in your network settings in your pc/laptop you should have dhcp turn on so press CTRL+SHIFT+ESC and task manager window should appear. Then File->Run.. and type 'cmd' and press ENTER. Black "dos" window should appear. Then type 'ipconfig /all' and press ENTER again and among lots of data you see you should find IP of your gateway.
May 08, 2011 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
I get network connection but unable to access my email.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu...To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive, When the Welcome screen appears click Exit, connect your USB adapter now...When the Hardware Update Wizard window appears, click Install the software automatically (Recommended) then click Next...Click Finish when the installation is complete...
NOTE: The Hardware Installation screen may appear indicating that the Adapter has not passed Windows Logo testing. Ignore the window and click Continue Anyway to proceed with the installation since the Adapter has been tested and found to work with Windows XP.When Windows has finished installing the driver, click Finish.
Click on Start and goto Control Panel and double click on Network Connections...Right click on Wireless Network Connection and select View Available Wireless Networks"- If you see your wireless network in the list, highlight it by 'single' clicking on it- Now click on the 'Connect' button below- If your wireless network is secured, it would ask you to provide the network key- Provide the wireless network key and confirm it again in the confirmation box and click "Connect".It should work...
Mar 04, 2011 | Linksys Computers & Internet
How to use my samsung wave as a modem
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem You need PC suit software provide by SAMSUNG
To use your phone as modem *install the pc suit software *Open PC suit and select "Connect too internet" *if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet For this you need *Bluetooth on your PC and phone
To connect(in windows OS) *Click on Bluetooth symbol on task bar *Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode) *Add your device to your pc Add completion of the above...
*Again click on bluetooth symbol on task bar *Select "show all devices" *now select your device(one click) at this time 4 options appears on top your devices list *select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar *Select "show all devices" *double click on your device *select connect to internet from the dialog box which appears after selecting the your device
Thank you
Jan 29, 2011 | Samsung Cell Phones
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
Open Network Connections
2.
Right-click Wireless Network Connection, and then click Properties.
3.
On the Wireless Networks tab, do one of the following:
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
Need to fax docs w/ a Dell 942 all-in-one print-fax-copy-scan.
To install and configure the Microsoft® Fax software:Click the Start button.
Click the Control Panel icon.
Double-click the Add or Remove Programs icon.
Click the Add/Remove Windows Components icon on the left side of the Add or Remove Programs window.
When the Windows Components Wizard window appears, click to place a check in the box next to the Fax Services listing.
Click the Next button.
When the Files Needed window appears, insert the Windows® XP CD into the CD-ROM drive.
From the Copy files from: drop-down button, select the drive-letter that represents your CD-ROM drive.
Click the OK button. to automatically open and close several installation windows.
When the Installation Complete window appears, click the Finish button.
Close the Add or Remove Programs window.
Click the Start button, point to All Programs, point to Accessories, point to Communications, and then point to Fax.
Click Fax Console.
When the Welcome to Fax Configuration window appears, click the Next button.
Enter any appropriate information in the fields provided.
Select your data/fax modem from the drop-down button located below the Please select the fax device listing.
Click the Manual answer button or Automatically answer after (specify number of rings) button.
Click to select the Enable Receive listing.
 Note:
  By selecting the Enable Receive check box, you can receive faxes. However, selecting this option may cause the computer modem to answer all incoming phone calls in which you may not receive voice mail.
Enter your TSID (Transmitting Subscriber Identification) information in the field provided.
Enter the CSID (Called Subscriber Identification) information in the field provided.
When the Routing Options screen appears, click to select the Print it on check box if you want each received fax to be automatically printed. If selected, use the drop-down menu to the right of this field to select the Dell AIO Printer to print the received fax. Your printer must be on and connected to your computer in order to automatically print faxes.
To create an archive copy of each fax, click to select the Store a copy in a folder check box.
Click the Browse button to select the desired archive location.
Click the Next button to display the Configuration Summary list.
Confirm your configuration settings are correct, and then click the Finish button.
You are now ready to send or receive faxes.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&dn=1091795
Nov 14, 2009 | Office Equipment & Supplies
I am having trouble with accessing youtube and facebook .when i go on them the page's respond is"Network Timeout
In this situation you can access other website? If not then goto Network connections on control panel, on your active connection right click then properties, this popup window will appear...
then select TCP IP.... If you are using modem at home with router then select Obtain IP address automatically and Obtain DNS Server automatically,
click ok until connection window closes, on the Command Prompt type ipconfig /release <ENTER> and ipconfig /flushdns <ENTER> ipconfig /renew <ENTER>
Wait until your PC leases IP address.
To test if you can access any website then type ping www.facebook.com, if there is reply then youre now connected.
State problems that you have encountered for further instruction.
Goto
Oct 21, 2009 | Computers & Internet
How to set dsl modem
You go to start menu and access the Control Panel. Open Network Connections and make sure the LAN connection is enabled. If not, right click and select Enable. After confirming LAN connection, then go back a page and click Internet Options. Then the page will automatically show you the General Tab. Type in (or verify) home page in the window. eg. www.aol.com . Then select Connections Tab. Remove any connections that appear in the window below. Below that on the same page, select LAN Settings. Check the Automatically Detect option. This will allow your PC to detect your modem and your internet service. Select OK at the bottom and the window will close. Click Start again and select the Internet Explore. If your internet service is active the window will open to your home page. Good Luck!
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Norton not loaded purchased from internet, did not get email with produt key, i'm 79 and mest it all up, please help me. mr james monksfild, email pelican12@talktalk.com. thank you.
ø First of All Shut Down your Computer.
ø Restart Computer and Keep Tapping F8.
ø Choose Safe mode with Networking and Press Enter. (Win XP or 2000).
ø Run Windows in Safe Mode Click Yes.
ø Restoring Windows to a previous point
ø Click Start, Programs or All Programs, Accessories, System Tools, and then System Restore. The Welcome to System Restore window opens.
ø Select restore my computer to an earlier time, and click Next. The Select a Restore Point window opens.
ø Select a bolded date and a restore point, and then click next
ø (Note: - You need to choose a Date before the installation of Norton)
ø Click OK if a pop-up window about closing programs appears. The Confirm Restore Point Selection window opens.
ø Click Next. The computer should shut down and turn back on automatically after the restoration completes. The Restoration Complete window appears.
ø Click OK. The computer has now been restored to a previous time when it worked correctly.
ø (Note: - If an error message appears saying that the computer cannot be restored to the point you selected, try a different restore point)
After the System Restore is complete, and the computer starts successfully, update the computer software as follows: - 1). Update the system virus definitions. 2).Get the latest critical system updates using Microsoft's Windows update.
Once all this is Done you Need to Download and Install Norton Again.
Jul 04, 2008 | Computers & Internet
Nokia 6600 Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
