Question about Linksys Wireless-G WRT54G Router
Forgot how to make secure connection
Good morning, i disconnected from my network and am having trouble getting it back to being personalized and secure and when i went to easylink it tells me my router is not supported? this is the Wireless G 2.4 GHz 54 Mbps Router? please help
  • 102 Answers
Have a look here
Posted on Jan 12, 2008
I use to have the ps3 hooked and on a new service moved forgot everything and trying to connect to the wireless interent and it keeps popping up psn failed
Everytime you disconnect from a network you ll have to go into the network settings again to reconnect. Find your wireless connection on the list, select your security, enter password and then hit "test". If all credentials were correct, it will quickly breakdown the connection attempt for you, showing you where the connection succeeded and where it failed to better triangulate the issue. If all connections succeed during the test, simply go back to the main screen and sign on. Hope this helps.
Apr 23, 2015 | Sony Playstation 3 (PS3) Console
Cannot get eee pc 1001pxb to connect to the internet. it has connected to a wireless internet, but not the wired connection. I have linksys wireless g router, but it is hard wired to all my computers. i...
Good Morning.
Do not worry, We will fix the issue for you.
Please open control panel >> network and sharing center >> if you see wireless network connection >> please disconnect it and >> connect the lan cable or wired cable to the laptop and start browsing.
This will fix the issue.
Jul 06, 2011 | ASUS Eee PC Netbook
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
My wireless keeps saying limited access and connected to unidentified network. When i trouble shoot it takes me the security settings where i have a choice of no authentication (open) shared wps2-personal...
Are you sure you aren't connecting to another network by accident?
Could just unplug your router, and check to see if you are still connecting to something.
Otherwise it could be the router needs rebooted, or you need to reconfigure the security on it.
What kind of device are you connecting from... phone or computer?
Oct 03, 2017 | Computers & Internet
Iphone / WiFi signal / Motorola SB5100 problem
Try turning 3g off, then make sure security of network is wep not wpa personal the iphone has trouble with that
Dec 14, 2009 | Apple iPhone 3G
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
Problems with wireless connection - gateway notebook
Might be several things, but perhaps start with checking for any driver updates that might be available.
Feb 11, 2009 | Gateway (802.11usb) Wireless Adapter
SECURITY PROBLEM
first go to router setting page, for access router page the default ip add is 192.168.1.1 try this first, if the router page is not open then check the default Gateway in u r pc and keep the ip add of ur pc ob tend automatically
1. when the page is open then go to wireless potion>wireless security>
2. then select encryption type WEP > 64 bits
3. then type pass phrase>click on "generate network key"
4. routher will generate 4 network key , select first key as wireless security key.
5. save this settings.
now the wireless connectivity automatically disconnected
6. now search the wireless network on u r pc .
7. when u get u r wireless network , then connect to this network
now the wireless network key is ask bye system ,
8. type the network key which generated by router .
and connect 2 u r wireless network
Aug 20, 2008 | Linksys Wireless-G WRT54GL Router
Can't add a printer to network
Hold reset on the router for about a min and a half while disconnected from power. You should be able to connect with both the PC and printer when powering up again.
Jun 20, 2008 | Office Equipment & Supplies
Blue screen at Microsoft second security package
Comment by ceryac, posted on Jun 26, 2008 This morning I have started getting the error message Bad Pool Header after my computer has been on line for about 25-30 minutes. RegCure said it can fix Blue Screen errors but it does not fix this.I have no idea why or what to do to fix it.
Regards
Ceryac
Apr 05, 2008 | Xterasys XN-2423G (XN2423G) Wireless...
Linksys Wireless-G WRT54G Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
