Question about Vacuums
Dirt Devil Vison Bagless Upright- adjustment wheels will not stay in position
The height adjustment wheels (not the casters) flip back and forth when using the vacuum, making this thing impossible to use. I see nothing that is designed to hold the wheels in the forward position toward the beater brush. Did some retainer break off that is not evident to me? Or is it time for a new vac?
5 Suggested Answers
debbily
  • 101 Answers
SOURCE: Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Posted on Oct 11, 2007
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
SOURCE: need instruction on dirt devil mop vac
I found very basic direction on eHow
Posted on Mar 20, 2010
I changed the belt on my dirt devil jaguar and can't get the front wheels back in the right place
Go to this site, scroll down to care tab and you will find the correct procedure.
http://dirtdevil.com/products/details/m085830t/jaguar-bahttp://dirtdevil.com/products/details/m085830t/jaguar-bagless-upright/gless-upright/
Feb 15, 2015 | Dirt Devil Vacuums
How do I keep the rear wheels from coming off my dynamite upright dirt devil
Plastic to plastic wears fast. I have repaired this problem by inserting small wooden dowels between the splits in the axles.( I have one of these machines in my home) Lubricate the axles with a non-petroleum grease afterward. I use Superlube available in most auto parts stores.
Nov 21, 2014 | Dirt Devil M084600 Dynamite Bagless...
The wheel on my Dirt ***** vacuum fell off. I tried putting the wheel back on but now the wheel is loose.
Hi! We recommend you take your vacuum in to a Dirt Devil authorized service center for repair. We have included a link you may follow to locate the nearest service center to your zip code. Hope this helps!
Service Center Locator
Aug 24, 2014 | Dirt Devil Featherlite Bagless Upright...
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
Jul 11, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
