Question about Logitech Z-2300 Computer Speakers
Logitech Z-2300 speakers
I have these speaker and the subwoofer suddenly stopped working. the 2 speakers are fine but nothing from the sub. i have checked the connections into the sub and the power, connetion to the volume/power pad and speaker connections are fine but the subwoofer gives no sound, no matter how loud or low the bass is.
any ideas?
thanks
  • 1 more comment
  • hereforyou Apr 06, 2009
    THAT WAS NOT THE PROBLEM. ANY OTHER IDEAS ?
    NOT HELPFUL. THE OTHER SPEAKERS WOULD NOT WORK IF THE FUSE WENT.
  • Anonymous Apr 09, 2009
    Yeah i took the fuse out and then speakers and sub stopped but the fuse could still possibly b fucked only letting enough power for the speakers through?
Maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Posted on Jan 22, 2008
My satellite speakers are no longer working, logitech do not issue replacement satellites. Do you know if their is a way to use alternative sattelites with the subwoofer?
the back of the sub has 2 rca connections for left and right speakers so all you have to do is either find satellites that use rca connections or find or make your own "clip-on" or detachable wire to rca connection.
Dec 24, 2010 | Logitech Z-2300 Computer Speakers
Hi, My friend left me his Z-2300 sub but lost the speakers that go along with the system. What speakers are the best replacement for the sub? which dont involve me soldering any wires!
I don't know which would be best but my recommendation to you is go shop around on the internet or in stores and find some good quality 2.0 (2 speakers without a subwoofer) computer speakers. If the speakers don't already have RCA connections it is easy to find a 3.5mm to RCA cable connector. Let me know if you want me to clarify that....audio lingo is very confusing sometimes!
Nov 01, 2010 | Logitech Z-2300 Computer Speakers
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
Jul 28, 2010 | Logitech Z-2300 Computer Speakers
Speakers dead
check for individual speaker resistance. or in the dividing network for some burn fuse or coil.
Apr 05, 2010 | Logitech Z-2300 Computer Speakers
Logitech THX Z-2300 only one speaker works. theres something wrong with the input. both speakers work fine but the 1 of the inputs on the subwoofer stopped working, causing only one speaker 2 work
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Jan 23, 2010 | Logitech Z-2300 Computer Speakers
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 computer speakers
Please recheck the connection of subwoffer once again..
thankyou...
Jan 02, 2008 | Logitech Z-2300 Computer Speakers
No sound out of woofer
Hello sparkie102
Happy Holidays
you have to check if all the cables are well connected, and in the right inputs. 2) check your software for sound that is enable, fine.
turn up the sub volume , if got it independent.
other that this, is a failure sub. if got warranty, use it! or RMS your sub.
Dec 26, 2007 | Logitech Z-2300 Computer Speakers
Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
535 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
