Question about Gateway FPD2275W LCD Monitor
Removing cover i use samsung sincmaster 793s monitor.i want to remove back cover of the monitor,can you pls help me?
    Problem Solver:
  • 19 Answers
Firstly you have to take off two screws from the backside. Secondly: there are two holes on the upper side, you must press in with small screw driver(one by one ) and pull backcover back.
I hope this will help you.
Posted on Jan 17, 2008
How to know our samsung crt black monitor 17" warranty?
Most SAMAUNG monitors have 3 years warranty.
It has 3 years warranty from purchasing date:
http://www.superwarehouse.com/Samsung_SyncMaster_793S-Black_17_CRT_Monitor/793S-BLACK/pw/422156
Please leave rating if it helps.
Jan 07, 2011 | Samsung 793S 17" CRT Monitor
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
A black flickering line about 5" from the bottom on my samsung syncmaster 793s 17" CRT Monitor
Hi rkarthea,
Well to narrow down the problem I would suggest first that you try to disconnect the monitor from your APC Back-UPS and just plug it directly to the wall outlet, UPS or surge protectors may cause interference at times with some electronic devices. Then if it's still here, I would recommend that you try to degauss the monitor, all CRT monitors have this option in the OSD. You should also check if there is any magnetic device near the monitor, like a speaker or phone that can cause this. If another PC is available can you try it there also, see if the problem is seen on another PC.
Finally, run the monitor self-test, to do this just leave the monitor plugged into the power outlet and disconnet the video cable, and you'll see it. If the problem is still there then most likely the monitor will have to be checked in a service center or be replaced eventually, since this would already be a hardware problem. Especially since you said the problem is apparent even in the OSD.
Hope this helps!
Peace! :)
Oct 23, 2008 | Samsung 793S 17" CRT Monitor
Monitor problem
1240/1024 and 75hz refresh rate
May 09, 2008 | Samsung 793S 17" CRT Monitor
VERY DARK COLORS ON THE SCREEN..
check power section the brightness control transistor could be open.The voltages are ok on rgb.check heater voltage
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | Samsung 793S 17" CRT Monitor
Monitor
Check relay in power section for fault.To degaus the monitor.
Jan 10, 2008 | Samsung 793S 17" CRT Monitor
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
