Question about HP DeskJet 930c InkJet Printer
Orange flashing light on printer
When trying to print any document, a message comes up "unable to print". A yellow light is flashing constantly (which is above the cartridge sign). I have checked the estimated ink quantity in the HP settings file and there is 100% colour and 20% black. I have also checked for jams and there are none. I have also reinstalled the printer but the light still flashes and does not allow me to print anything. Is the black ink too low?
  • Anonymous Jun 17, 2008
    Hi the orange light keeps flashing I have a full cartridge in and also paper but it still will not print can you help please
  • 417 Answers
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Posted on Jan 12, 2008
Bought this printer used. No manual came with it. There is a constant orange arrow pointing down. Help Margaret
Hello Margaret, I found the manual for the DeskJet here:
You can view it by clicking the link or you can print it out. Hope that helps.
Mar 05, 2011 | HP DeskJet D2560 InkJet Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
The light first flashed orange causing printer to pause printing. After restarting the machine and printer several times, it is constantly flashing green. printer did not initiALISE.
The light flashing orange or green could mean a couple of things. First could mean that the paper size that you are using is not the same that you have configured on the printer or the paper size that you have selected on your software is not the same as the one configured in the printer. Also it could be a message of the toner low. You can try resetting he printer to factory defaults. Turn Printer off and open the front cover. Then Press and hold the Button with the Triangle and the Cancel Button the one with the X and turn the printer back on. You will have to keep the buttons pressed until the exclamation light comes up solid then release the two buttons and close the cover. That should reset the printer to factory Defaults.
Dec 15, 2009 | Lexmark E120n Laser Printer
Both green and orange lights blinking. Printer
Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
Oct 09, 2009 | Castelle LANpress Jr. MP (66298601-040)...
Printer wont go online - light continually flashing green to yellow...
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
May 24, 2009 | Office Equipment & Supplies
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
HP DeskJet 930c InkJet Printer Logo
1,007 people viewed this question
Ben Johnson
