Question about Samsung LN-S4092D 40 in. LCD HDTV
Actually it a lnt5271f, but...
I can't get cable TV to work. It shows weak or no signal. OTher TVs in the house work, so it's not the cable.
I can use the DVD and the gane systems, but not the regular TV, an ideas?
  • buckeyeangel May 29, 2008
    all we are getting when we hook up the direct tv is weak or no signal. what do we do?
  • 61 Answers
There is a differnece between other TV's in the house working and the TV at that specific location working. Check the cable splitters which go into that room and tighten the cables at all ends..loose/broken cables cables can result in weak signals. It might be a bad splitter too.
Posted on Mar 03, 2008
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
37" LG flat screen is
With the onset of more and more TVs being hooked up to cable, TV manufacturers didn't need to make the tuners as sensitive because the signal from the Cable Co. was much stronger than the over the air signal. If the other TVs are older they may be just sensitive enough to lock onto the channel signals. You could ask your cable provider to check your available signal in the house to see if there is the proper amount of signal. Some channels can inherently be stronger and when "block converted" (put where the cable company wants the channels) all come thru but some are a bit clearer.
Aug 28, 2011 | LG 42LG30 42 in. LCD HDTV
I swiched my sharp from a working Bell PPV satellite signal to a working standardCable Coaxial connetion from Rogers, while my two samsung tvs are working onthe rogers coaxial signal, the Sharp is not...
Good day!!
OK please try to go to the menu using button on your TV...after that find the auto scan mode...
please complete the 100% scan for better results...
if the problem persist try to play DVD or any recorded TV show to determine if the problem is on the signal or on the TV itself (the tuner is weak)..
Jul 10, 2011 | Televison & Video
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
No Cable TV
This is due to either weak\no signal, or too many splitters. How many TVs do you have and how many cable boxes? I've had this happen where squirrels or other critters will walk across\chew the lines coming into the house and then rain will affect signal up to 90%. My internet would work but the TV would be off. Most likely it's a wiring issue, you may have to wait for your provider to visit.
Oct 24, 2017 | CTG Computers & Internet
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
Jun 09, 2008 | Televison & Video
Frames freeze every few seconds
Sounds like a weak cable signal. Contact your cable service provider and ask to have a tech check your incoming line strength.
Sep 10, 2007 | Toshiba 72MX195 72" HDTV
Samsung LN-S4092D 40 in. LCD HDTV Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
