Question about Car Audio & Video
Repair subwoofer the wire connecting the negative jack to the voice coil is missing and where it e.nters te ciol is a little melted. i was wondering if the experts can tell me how to fix it (as a little project/hobby) and if i can.
  • Anonymous May 10, 2008
    the inner wires are burn on a 2000 watts subwoofer how do change them i can get the speaker open
    New Friend:
  • 101 Answers
Http://www.mwaspeakerparts.com/
as long as the bsasket or magnet is not warped it is repair able.
Posted on Jan 22, 2008
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
How to bridge a dual voice coil subwoofer, the sub has 4 speaker wire connections coming out the back how do i bridge it two one
You have two choices of how to wire this sub.
First, is an 8 ohm load. This is called a series set up. Go from the positive of the amp to the positive of one voice coil. Then go from the negative of that voice coild to the positive of the other voice coil. Then go from the negative of that voice coil to the negative of the amp.
Second is a 2 ohm load. This is called a parrallel set up. Go from the positive of the amp to the positive of both voice coils. Then go from the negative of the amp to both negatives of both voice coils.
Make sure your amp can handle a 2 ohm load. If you have two subs, you will need a 2 channel amp.
Sep 01, 2011 | JBL GTO1214 Car Subwoofer
How to hook it up for one ohm
oh yes the JBL GTi W15GTI Mkll. this subwoofer is a dual 6 ohm voice coil subwoofer. This is impossible to run this sub alone and get 1 ohm you will need another JBL GTi W15kll. the lowest impedance you can go to is 3 ohms. you can achieve this by connecting the positive terminals together and then running a wire from the two positives to the positive terminal on the amp. then connecting the negative terminals together and then running a wire to the negative terminal on the amp. this is a real nice sub it just has that one down fall of having a six ohm voice coil.
Aug 01, 2011 | JBL GTi W15GTi MkII Car Subwoofer
How do I wire my 12inch mtx ts 55 subwoofer two outlets red with red and black with black or red and black and red and black
The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Jun 17, 2011 | MTX TS551022 Car Speaker
I cannot find a diagram of how to wire a boss audio phantom p128dc dual voice coil subwoofer with there being 4 binding posts on each side of the woofer.
I will assume that you mean four posts total and not four on each side. It's a dual voice coil and you will need a jumper. Take a small strip of speaker wire and connect the positve and negative of one coil together. Take a close look, there is a dot on one positive and a dot on one negative. Jump these two together. Now wire the other positive and negative to the amp's positive and negative.
May 24, 2011 | BOSS AUDIO SYSTEMS P128DC Car Speaker
Dont know how to connect daul voice coil on a icbm-5612 performance teknique.
If you want a 2 ohm total load..wire it from the amp positive(red) to the first coil positive(red) and then to second positive(red). Amp negative(black) to first coil negative(black) and then to second negative(black). This will give you a 2 ohm total load on the amp.
Apr 21, 2010 | Performance Teknique ICBM-6112 12" 4 Ohm...
Wiring 12" icmb-5612 preformance teknique subwoofer
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
SUB WOLFER WIRING
im assuming you have 2 subs that are DVC? if thats the case, wire from the positive on the amp to the positive voice coil 1 on sub 1 to the positive on voice coil 1 on sub 2. then do the same with the negative sides. then on the second voice coil of sub 1, connect a wire from positive to negative. do the same for sub 2.
Nov 27, 2007 | Car Audio & Video
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
254 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
