Question about Linksys Wireless-G WRT54GS Router (e125894)
WRT54GS V6 I what to add a range extender to my existing and fully functional wireless network, and have a WRE54G V1 extender, I keep getting a cannot work with AP in pepeter mode error on install of extender. Have updated the router firmware fm linksys site to V1.52.2? Any solutions?
  • bfh522 Jan 16, 2008
    I guess I am the only one with this problem.
    Problem Solver:
  • 8 Answers
Leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Posted on Jan 17, 2008
Firmware upgrade wre54g
Go to the Linksys website, SUPPORT, to section called START HERE, type in your model number. Follow their instructions.
Jul 17, 2014 | Linksys : WRE54G Wireless Range Extender...
Extending the reach of youir wireless internet
To significantly increase your Wi-Fi coverage (often by up to 40 percent) is to add a wireless repeater or range extender. You should place this repeater at the outer (but good) range of your existing router's coverage and it should repeat the network signals between the existing router and any Wi-Fi computers and devices that wirelessly connect to the repeater.
Feb 12, 2014 | Computers & Internet
Netgear ext
Once the range extender is in "discover" mode it will find your existing wireless network. It will then take the name of it and add '_ext' to it. giving you a second wireless network. For instance, if your wireless network was called my-house, the extender would create one called my-house_ext.
Dec 23, 2013 | Dell Computers & Internet
My friend has a linksys router. (Not sure on the model). But I am trying to set up a WRE54G-RM range extender. I am able to go the setup, but then when I get to the point where I have to change some of...
Is the router set to allow extension of the network?
Is there MAC address filtering set up on the router?
Are you certain that you are connecting to the correct router? To be sure, change the SSID to something unique and not the default of "linksys".
Let us know how it goes and feel free to ask additional questions.
Thanks for using FixYa and Happy New Year!
Dec 31, 2010 | Linksys WRE54G-RM 802.11g/b Wireless...
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
Try to reset WRE54G
Resetting the Range Expander to Factory Default
The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
NOTE: The default IP address of a range expander is 192.168.1.240.
After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
Checking Physical Connections
Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
Checking LEDs on the Network Adapter
Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
Assigning the Computer a Static IP Address
For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
Checking the Computer's Connectivity to the Range Expander
For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
For instructions on how to restore the range expander to factory default, click here.
If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
Connecting Wirelessly to your Range Expander
NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
Step 1:
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
4146-005.pngStep 2:
Click Site Survey then select the SSID of your wireless range expander and click Connect.
NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
4146-007.pngChecking the Computer's Connectivity to the Range Expander
NOTE: If you're using Windows 98 or Windows ME, click here.
If you're using a Mac computer, click here.
Windows 2000/XP
Step 1:
Click Start, then click Run.
Step 2:
When the Run window appears, in the Open field type "cmd", then click OK.
3984-003.pngStep 3:
When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
Step 4:
See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have a clearwire modem. I have to locate it 80 ft from my two home desktops and laptop. i need to know how to best do this. i have an e2000 router that i was hoping to use a wre54g range extender...
The Linksys E2000 router is N series router and the WRE54G is G range expander.
WRE54G is only computer with the WRT54G and WRT54GS routers.
You have E2000 router. I believe that router is capable of broadcasting the wireless signal upto 100 fts.
As Linksys says that router is capable of signal up 200 - 300 fts, but it is not.
You can try changing the wireless channel on the router to increase the signal.
Open the setup page of the router.
Go to wireless tab and change the configuration view to manual.
Try changing the channel to 11, 9, 6 ,1. See if that works.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys Computers & Internet
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
Linksys wre54G range extender - lights went out and despite unplugging, disconnecing, autoconfig. and reset button maneuvers, there are no lights and no function. What's going on??? Is it broken, burned...
have you recently changed the firmware in the unit. you may wish to go to the linksys website and download the correct firmware for the unit and reflashing it.
do a google search on "bricked" routers, i've repaired a couple and it's semi-complicated but it does work.
Sep 25, 2009 | Linksys : WRE54G Wireless Range Extender...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
Linksys Wireless-G WRT54GS Router (e125894) Logo
221 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
