Question about HP LaserJet 2100 Printer
Ink transfer you can read already printed info on blank parts of the paper. like ghost images
  • 417 Answers
Hi there have you tried changing the toner cartridge? if not please do so as this can sometimes cause this fault, but the most common cause is the fuser unit at the rear of the machine where the toner is welded to the paper. The top roller gets worn and causes the ghosting. The only way to stop this is to replace the fuser unit which you can purchase and is still cheaper than a new machine.
Thanks J
Posted on Jan 12, 2008
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother MFC-7820N Laser Printer
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
The printer is transferring ink from the top left of the paper all the way down in line with the rollers. It looks like a smudge but you can see the print. I have cleaned it, but still has the problem. Any...
Image problems on laser printers are almost always caused by the toner cartridge or the fuser. If you have already tried a new toner cartridge and that has not fixed the problem you need a new fuser. A fuser that is going bad will cause lines, smudges and ghost images. You can buy it alone or as part of the maintenance kit. www.printerworks.com is a good place for HP parts. Search by model number to see what you need.
Oct 05, 2009 | HP LaserJet 2300 Printer
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
HP LaserJet 2100 Printer Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
