Dell Dimension 2400 PC Desktop
Problem for Dell Dimension 2400 PC Desktop
System cannot boot
By ericwish on Jan 12, 2008
System refuses to do anything beyond first Dell screen when booting. No Setup menu, no boot menu, nothing, just blinking horizontal cursor. Began occurring after installing Windows Updates. Diagnostic lights indicate possible error with expansion card (VisionTek Radeon 9200 SE 256 mb PCI) but I tried each different slot, then using on board graphics port, still nothing.
Same Problem
Nov 19, 2008
-   I Have the same problem. I plugged in a power supply diagnostic unit. Light D on the back is amber. Diagnostic unit shows negative 5V is missing. I'm going to change the power supply. -   Guest
Oct 31, 2008
-   not open the booting system
-   onmygilo
Feb 11, 2008
-   Computer just boots to horizontal line. c and d lights aon back of computer are amber-   eichenbaum
Best Solution
posted on Jan 12, 2008
Helpful)
PaTcH1313
Rank: Master
Rating: 87%, 20 votes
huh that is odd, you might want to try f8ing the start up and running "Last know good configuration that worked" or you could try booting it in safe mode. You also might try reformating the drive you installed the updates too. Another thing that can cuase it is your RAM you might try booting with only one stick of RAM in. Try thoughs and let me know what you found out
Was this helpful?
Yes
No
Solution #2
posted on Nov 19, 2008
Not Rated)
techniwiz
Rank: Wiz  Dell Expert
Rating: 79%, 147 votes
this is not really odd one of the drive is creating a faliure or the printer is the culprit
disconnect all the drives and see it should go the screen that says no boot device found
than connect one by one
and you will find the culprit drive
before doing this try disconnecting the usb devices and start the computer
if this works disable the usb emulation from the bios it would be under onboard devices
and regards the other issues listed in the same query
the guy with c and d ember
remove the memory cards and put it again
if u have a dimension 2400 remove the cpu heatsink and put it back
Comments:
Nov 19, 2008
- the one with the not open the boot system
disconnect the printer and start
Nov 19, 2008
- the one with the 5v missing try reseating the cpu heatsink
dimension 2400 had the heatsink as a common issue
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 2400 PC Desktop
Questions and Unsolved Problems for Dell Dimension 2400 PC Desktop
Do you recommend Dell Dimension 2400 PC Desktop?
Answer
Answer
We have a 2 yr old Dell Monitor and it will not turn on. The switch just quit working. hate to junk... (More)
Answer
How do I open a Vaio PCV V100G case to add memory?
Answer
Drivers for nikkai usb 2.0 tosata and ide adaptor
Answer
I forgot to say in my last post that I do know about using Cntrl-+ or scroll to enlarge type size on... (More)
Answer
Hi there, Thanks for using fixya. What is the operating system running on PC? Since when you are... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
