Question about Canon PowerShot A540 Digital Camera
Display I guess I was a little to rough with my camers and hit the display screen and ruined it, is there anyway to replace just the screen rather then buying a new camera?
  • 1Sarah Jan 12, 2008
    ya b more careful lol <3 -T
  • Canon Master
  • 4,738 Answers
Here's some examples of how to do it on several cameras. The biggest problem would be acquiring a replacement screen at a reasonable price. Suggest getting it from a broken camera from ebay, but with a stated working LCD.
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Posted on Jan 15, 2008
Is there anyway to clear the electric throttlebody on my 2011 Buick Lacrosse CX L. It runs but it's real rough
Clear or do you mean clean ? Why don't you take your vehicle an have it diagnosed , instead of guessing what's wrong. There are a lot of thing's that will make a modern vehicle run rough . Electronic throttle body's for GM need special cleaner or you ruin the throttle body . Your vehicle also has VVT - variable valve timing , do you change your oil regularly ? The cam timing is changed by oil pressure . Have the vehicle check for DTC'S - diagnostic trouble codes .
Jun 30, 2016 | Buick Cars & Trucks
2003 Ford Windstar 3.8 143k rough idle stalls & engine lite runs good after warmed up. Local yokel guessed at leaking intake gaskets. Any thoughts? burdfrenzy@tampabay.rr.com
I have a 2003 ford windstar.Engine started to run rough when it
used to rained.I would accelarate it until roughness would go away sort of.It lack a little power but if I take it a mechanic they would charged too much money.Anyway, the problem was a spark plug wire in front of the engine, wires that are grouped together with that little pin. One of them was rubbing agains the valve cover and it got worned out current would leak out right there.I discovery it one time that it rainned really hard I had to go out and the wagon started to miss really bad and it wouldn't move.Finally, I got home the next day I looked under the hood to see what I can see and there it was a spark plug wire that one can tell if you know a little bit about cars that current was leaking throw it. I replaced wire problem solved.But now after all of that snow we had the check engine light came on and I am not sure what could be.For I remmerber running over a mountain of sort of hard snow.So it probably broke oxigine sensor wire.
Nov 26, 2010 | 2003 Ford Windstar
Focusing screen information bar slanting
A scratch on the screen will not effect your photos in anyway, it will just be annoying to you at most. Its possible to hit the prism out of alignment but also very unlikely. If you had to **** it a little bit, its possible you may have moved the actual lcd.
Apr 12, 2010 | Canon EOS Rebel XSi Digital Camera
ASUS Eee PC 900 -display screen was ruined during a flight - it
I should expect that a replacement is possible. You will need to try local computer shops etc.
Nov 22, 2009 | ASUS Eee PC 900 PC Notebook
The menus keep popping up when all I want to do is shoot photos. How can I better control the display menu on the viewfinder. I'll take a picture and then the display shows up. It ruins the spontaneity of...
Could you explain in a better way your problem?
The XSi don't show the menus on the viewfinder, it only shows on the back screen.
You can shut if of by hitting the "DISP" button just at the left side of the viewfinder.
You can also enable the screen to go ON or OFF, when you go close your face to the viewfinder, so the screen will be OFF when you get close the viewfinder, and ON when you move back your face
I'm trying to figure out how the menus can ruin a picture.
Let me know more about your problem.
Jul 08, 2009 | Canon EOS Rebel XSi Digital Camera
IBM R40 Screen Problems
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
Apr 14, 2009 | IBM 11P836402 for ThinkPad R40 Monitor
I crushed the screen of my Canon Powershot SD450 camera. Pls. estimate cost of screen repair. Is it on the screen thats cracked cozi can still take photos but cant see them.
Many screen breaks happen to ruin the LCD from visibly displaying a picture. On some cameras, the screen is attached to the back plate of the camera and are very easy to replace with a new one. Some screens are attached to a video pc board and may ruin the board from displaying anything. Your best bet is to have it repaired professionally by one of our top repair providers and get an estimate first. I have repaired many good digital cameras with a LCD replacement, but I also had to purchase a broken used one for parts because new parts became to expensive to repair the one with a broken LCD. BTW: all digital cameras contain many PC boards and if you can still take pictures means the boards that control your lens, motors, CCD, and I/O boards are still intact and functional. Hope this helps - fotobean
Feb 20, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Lens Broken
the lens is what the camers sees somewhat like the human eyeball, you loose your eye you can't see, brake the lens the camera cant see
Jan 03, 2009 | Cameras
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
Security camers not displaying on
Try going to that input and changing ntsc/pal or make sure your closed captions are off.
Nov 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Canon PowerShot A540 Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
