Question about Samsung TXM2796HF 27" TV
Samsung TXM2796HF Turns off after 45 min to 1 hr
The TV works great and has great picture and sound until about 45 minutes to 1 hour of being on and then it turns off and won't mturn back on until after it "cools down". It seems that something is overheating and shutting it down. I took the back off and made sure there was no dust build up on the inside. This made no difference. What is overheating and causing it to shut down?
  • 4 more comments
  • segull Feb 20, 2008
    I have the same problem. Have you found a solution?
  • Anonymous Mar 03, 2008
    March 2, 2008: have the same auto cut-off problem every 30 minutes
    starting February 22, 2008, cleaned dust by vacuum from the outside of
    cabinet, did not open the cabinet...too scared. I unplug for 5 minutes,
    then it comes back on for 30 or more minutes, purchased TMX2796HF
    from Sears in October 2002. Sometimes it will stay on for an entire 24
    hours before going through a turn off cycle...Margaret
  • Copier Connection
    Copier Connection Mar 22, 2008
    EXACT SAME PROBLEM. REMOVED BACK COVER BLEW OUT DUST W/CANNED AIR. WORKS BETTER, BUT WILL STILL OCCASSIONALY TURN OFF. BEEN TOLD POWER SUPPLY. ???
  • Anonymous Mar 24, 2008
    I have the same issue, I haven't sleaned it out (have not opened it) wondering if a simple power supply swap woudl fix this.
    Any idea's anyone fix this issue?
  • MurrayMc Jul 26, 2008
    I have the same problem. Turns off, then won't restart for a while.
  • Anonymous May 11, 2010
    Top Expert:
  • Samsung Master
  • 12,962 Answers
Probably some component in the power supply. Look for a leaking or swollen capacitor. They can change value during operation unlike a diode or transistor that either works or does not work. U might even remove and test all caps in the PS area and replace any one that is questionable regarding its specs.
Posted on Aug 30, 2017
6ya staff
SOURCE:
smile2u
  • 3 Answers
SOURCE: On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Posted on Dec 12, 2007
phoenixcomm
Cris Harrison
  • 18 Answers
SOURCE: samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Posted on Feb 12, 2008
Anonymous
SOURCE: Samsung DLP TV shuts off
I had the same problem and stumbled on the fix. It seems there is a factory defect. Open the lamp cover and you will probobly notice that the blue shut off switch on the left side is landing on top od the lamp cover. Reach down with a pencil or something and make sure the switch is under the tab on the lamp cover. My 50 DLP has not shut down since I set the switch properly. Free fix... try it.
Posted on Jun 25, 2008
Anonymous
  • 121 Answers
SOURCE: TV shuts off
prob  erratic connection  on pc board finding same problem.
Posted on Dec 01, 2008
Anonymous
  • 108 Answers
SOURCE: Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Posted on Jan 06, 2009
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
What it the next step in find a solution for my tv. replaced the power board, but same issue still happens. TV will cycle on & off for 45 min. with a screeching nose then go to no picture but audio
Sounds like backlight inverter board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screetchng sound are the common fault with this board.
Oct 12, 2015 | Samsung LN46A500 46 in. TV
Grace walks 80m in one minute. how far does shewalkin one hour in kilometers
First we look at the constants that we know. First we know 1 m = .001 km so, 80 m = .08 k. Second we know 60 min = 1 hr or 1 min = .016667 hr. So, plug in piece by piece what we know 80m per 1 min = .08 k per 1 min = .08 k per .016667 hr. this can also be written as .08/.016667 k per hr which is 4.8 kilometers per hour.
Apr 05, 2011 | Sharp EL-1701C Calculator
My Samsung HD TV 50" progressive Monitor goes off and turns dark
Samsung HDTV will stay on when turned on the temp lamp and timer light are flashing continually. what should I do to eliminate this problem?
Dec 08, 2008 | Televison & Video
30-45 min into use the picture goes black
Sounds like something may be broken try calling the place where you bought and if the warrenty is still in effect you can get a replacement
Nov 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Samsung hlp5674w
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Samsung TXM2796HF 27" TV Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
