Akai lct42z6tm Help, I just bought this t.v. no manuals How do I hook up my cable no cable connecter ????
  • greenduck
    greenduck Apr 10, 2008
    why do we need a cable box just to connect the cable from the wall into a t.v. without the correct jack? is there a cord that is coaxial on one end and the three way split on the other?
The "tv" you bought is actually a monitor, meaning you need a cable converter box to actually watch cable with it.
Posted on Jan 30, 2008
Where can I get a factory remote control for a Akai model number #LCT42Z6TM LCD television. Thank you. Casey Dawson
Try website like Remotes.com to buy the tv original remote.99% will find a original remote or a very closed compatible one.This site have the most remotes for tvs models and electronic units devices around.
Jun 29, 2011 | Akai LCT42Z6TA 42 in. LCD Television
Without a coax. imput , how do i connect my cable
You have to use a cable box using the Red, Grn, Blue outputs along with the red & white audio, or use the HDMI if the box and your set has it.
Apr 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Akai LCT42Z6TM Problems. Help?
I'm working on one now. So far, I've found two capacitors on the power supply board bad, both 1000uf/16V 105 degree caps location EC9 area. Still have mild interference on the screen which seems to change with the type of video being displayed.. Will look for C301 next, is it on the signal board?
Jan 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Fixed capacitors but now my colours are jumbled
It should have a year parts and labor warranty with the manufacterer. Contact Akai for auth serv. you will void your warranty if you tamper with it.Check connectiond on t con board lvds cables. same on all inputs?T con board could be bad.
Sep 13, 2009 | Televison & Video
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
I have this akai tv model lct42z6tm and connected to a vcr video output to the video input of the tv.it works for about 2 minutes and suddenly it shows grayish horizontal lines and the it scrambled all...
You may have bad capacitors on the main board where the signal is processed. These caps are as labeled: c280,c323,c302 and c320- replace this one first (it usually fixes the problem) Replace these caps with 100uf @35V
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
AKAI 48 in. LCD HDTV with bad signal board
Option 1
The web site shopjimmy.com has tons of parts for your TV.
I looked through it and they don't have a signal board right now.
It's the best place I know to find the parts you need.
Sooner or later, they should acquire one.
Option 2
Fix the signal board.
Try to find a SERVICE MANUAL for your TV on the web. This manual will have parts list, schematics, and test points for circuit boards for your TV.
A electronic tech should have no trouble fixing it.
Good Luck
Akai lct42z6tm
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Feb 21, 2008 | TruTech PLV16320 Television
Televison & Video Logo
346 people viewed this question
Top Televison & Video Experts
