Question about Maytag Performa PAV2200
Washing machine not spinning
The belt is spinning when in spin cycle but the tub itself is not. What can be the problem?
    Scholar:
  • 196 Answers
You may very well have a frozen brake located at the bottom of the transmission. Take the belt off and turn the large wheel in both directions. The wheel should turn easy in one direction and tight in the other. We are concerned with the tight rotation. Turn the wheel by hand. Directly above the wheel is the brake. Watch to see if the brake lifts up and turns. If not then the brake will need serviced.
Posted on Jan 13, 2008
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Washing machine will not spin
Hi, If this model has a belt, you might need to replace it. Once the belt gets wet, they are ruined. If the motor runs during the spin cycle and the tub does not turn, it is most likely the belt. If the motor is not running in the spin cycle, we need to look at other causes. If I can assist you further, please get me a model # so I can see exactly what washer you have.
Thanks
Vic
Jul 17, 2009 | Washing Machines
My washer does not spin in the spin cycle.
if it works on washing cycle and only not works in spinning cycle then you not need to see the belt it is the same. check the "no spin" mode check draining filter
Jun 06, 2009 | Kenmore Washing Machines
Tub doesnt spin after wash or rinse cycle
if it goes thru the wash cycle , is NOT a belt problem , what could be is a sensor switch located underneath where the door closes , its like a latch switch for security when it goes to spin, hope its helpful AJ
May 14, 2008 | Washing Machines
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Mar 07, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
