Question about Epson Stylus Photo R340 InkJet Printer
Printer head won't go back into non print position
The printer fed too much paper and stopped, I pulled the paper out from the back. Now the printer head won't cycle into it's non print position. It tries, but it is sitting up too high.
I only use this printer for photos and so even though it's several years old, it's like new because I don't use it for every day printing.
The error that comes up says "A printer error has occured. Please see your manuel" Which I did and it said to call Epson, which I did and they say I need to take it in for service. Can I fix this myself or do I really need to take it into have it serviced. Epson said to buy a new printer of course.
  • 63 Answers
The issue that your having is a hardware issue. There might be something wrong with the gears or the printhead. This is a very complex process if your going to fix it yourself.
Posted on Feb 07, 2008
Hp deskjet D1663 Pulls papers non-stop and output is blank
Perform a head cleaning process in you printer, If it is not helping the print head is faulty, take it to service shop
Apr 22, 2014 | HP deskjet d1660 inkjet printer - color -...
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
I'm getting an error code of W8102. Can anybody out there tell me what that means??
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
May 18, 2010 | Canon BJ-W9000 Copier
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
Error code b300
be re-done.
Oct 08, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
The INK Store
Dec 14, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Paper feed problem
The fault is the paper stop sensor is broken. Have the same problem myself. I don't think there is an easy solution to this as the sensor arm will have to be replaced and I think the m/c would have to be stripped down to do it. Nice to know if anybody has any ideas though.
Nov 09, 2007 | HP PSC 2355 All-In-One InkJet Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Mar 15, 2007 | Brother HL 5140 Laser Printer
Epson Stylus Photo R340 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
