Goodman GMS90703BXA Heater Logo
Posted on Jan 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Goodman furnace motor is dirty
Due to dust and dirt accumulation, my motor furnace motor is whining. How do I clean the internal parts?
  • mrsteddybear Jan 13, 2008
    Just an FYI. I wasn't asking how to clean the internal part of the motor, I was asking how best to clean the internal portion of the housing when you take the front cover off. (smile) It's VERY hard to get my hands inside to clean in there; nevertheless a vacuum hose. Also, there is no whistle sound, just a slight odor coming out of the heat registers and a sound when the blower motor kicks on, I'm guessing because of the dirt and debris buildup. Thank you!
Anonymous
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Jan 12, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
260012
Points
581
The blower motor, squirrel cage (fan) and its housing can be removed as a whole part. Disconnect the wiring harness to the motor, remove the ground wire. Look for a couple of screws that mount the blower housing to the furnace. they will 5/16 head size and usually be at the top. The bottom slides into a metal notch on the frame. With a little work and maybe a few cuss words, pull the whole thing out. A shop vac or air compressor will remove the dirt. Some dirt may be determined to stay, so a stiff bristle brush may be needed. Replace in opposite way you removed it. If the whistle remains, check the duct work and metal panels, and anywhere there is a gap or tape. This may be the cause of the whistling noise, but cleaning the vent holes in the motor and the fan blades cant hurt and will help the efficiency of the system and increase the life of the equipment. If the whining is the little vent motor up top, then try oiling with a thin turbine type oil, or just replace it, as they are relatively cheap. If you are asking about cleaning the internal parts of the motor, I wouldn't recommend doing that. If there is an oil port on the motor housing, use the oil I recommended earlier. Most likely it has a sleeve bearing not a roller type, so that's about it.
I have a Ward floor funace, the pilot lights but doesn't heat up.
The usual culprit here is dirt. The pilot burner should look like a small blue blowtorch with a sharp flame, but if the pilot flame is soft and keeps being blown around like a candle, then it means its dirty and needs to be cleaned.
You need to take out the whole pilot burner and disconnect the pilot tubing at the base of the pilot burner. Remove the pilot orifice and clean it with a wire from a wire brush, or by blowing out the dust and dirt in the pilot orifice.
Clean the rest of the pilot burner with a wire brush or by blowing air over it to get rid of accumulated dirt and crud
You can also inspect the vent pipe for damage or corrosion, pull it out of the chimney to see if there is any dirt accumulated at the bottom, which can block the combustion gasses from going up the chimney.
PS! A neglected furnace poses a significant risk of carbon monoxide poisoning if it isn't properly maintained!
Hope this helps.
Gas furnace inducer fan make whistling sound before burner fires
A whistling sound from the inducer fan of a gas furnace is often an indication of a problem with the fan, which could be due to several reasons such as:
  1. Dirty or clogged fan blades: Over time, the fan blades can accumulate dirt, dust, or debris, which can impede the flow of air and cause a whistling sound. In this case, cleaning the blades can often solve the problem.
  2. Worn out bearings: The bearings in the fan motor can wear out over time, which can cause the fan to make a whistling sound. If this is the case, the motor may need to be replaced.
  3. Damaged or loose fan blades: If the fan blades are damaged or have become loose, they can cause the fan to vibrate and create a whistling sound. In this case, the blades may need to be repaired or replaced.
  4. Improperly sized ductwork: If the ductwork is too small or improperly sized, it can cause air to flow through the system at a higher velocity, which can create a whistling sound.
It's recommended to call a professional HVAC technician to inspect and diagnose the issue with your furnace and perform any necessary repairs or replacements.
Goodman gmvc950704cxab Code 88
Turn the power off at the breaker. Wait 10 minutes and turn it back on. That is the closes you get to a system reset, however, they say this
How do you reset a Goodman furnace?
Press and hold the red "Reset" button in the center of the rollout limit switch component. Hold the button for one to two seconds before releasing it..
This says Code 88 is a dirty filter. After the reset, pull the filter out and try again. If it runs, vacuum the filter and buy a new one next time you are passing Home Depot.
There is also an Error E8
E8 High Stage Pressure Switch Stuck Close at Start of Heating Cycle
Goodman furnace error code 88 - ROMA Heating HVAC AC LTD
https://romaheating.ca > goodman-furnace-error-code-88
Jan. 7, 2021 - Your furnace may be blowing cold air because the filter is too dirty. A dirty air filter blocks airflow over the furnace's heat exchanger, ...
Missing: gmvc950704cxab ‎' Must include:
gmvc950704cxab
Diagnostic Code Identification System
https://mobile.goodmanmfg.com > faultcodes
Once all menus have been satisfied push the SUBMIT button. 5. To reset the search for a new search click the SEARCH button. © 2011 Goodman Manufacturing Company ...
Goodman GMVC950704CX Installation Instructions Manual
https://www.manualslib.com > manual > Goodman-Gm...
Goodman GMVC950704CX Manual Online: Status Codes. S TATUS C ODES INTERNAL CONTROL FAULT/NO POWER O P NORMAL OPERATION E 0 LOCKOUT DUE TO
My Maytag dehumidifier filter doesn't ever get dirty why
Unless you have it installed in an especially dirty area, the filter hardly ever gets any appreciable accumulation of dust and dirt. The manufacturer turns on the clean filter reminder after so many hours of operation. Never is it indicative of detected dirt clogging filter. Just hit the filter reset button on the control panel
Compresser want stay running
Your problem could be as simple as dirty condenser coils or a burned out condenser fan. These components are on the bottom of the refrigerator and removing a couple of panels should give you access to them. Clean dust and dirt off the coils and check to see if the bottom fan is running when the refrigerator is running.
What is possibly happening is that excessive pressure builds up in the refrigerant lines due to the lack of air moving over the coils, caused either by a dust and dirt accumulation or a burned out fan. Or both. I know this may not sound logical, but dust and dirt is your refrigerators number ONE enemy. You'd be surprised how often this relatively simple (and FREE) fix will correct your problem.
Whirlpool refrigerator runs fine then shuts off & will not restart unless you turn it off & back on
How do I clean the soot and dirt out of my empire furnace?
If the furnace has been service annually there shouldn't be any soot in it. Soot in a furnace is caused my incomplete combustion, due to clogged or dirty burners. In any event, the bast way to clean it is use a shop vac with a brush attachment of the hose. A crevice tool will also be helpful.
To keep the soot in the shop vac, it's a good idea to purchase a dust back to fit that shop vac. They're normally used fro vacuuming sheet rock dust, but work equally well for soot. DO NOT use a domestic vacuum cleaner.
But, before you do anything, make sure the pilot light has been turned OFF and the furnace is cool.
Remove the front panel(s) of the furnace/heater and you will access to all of the inner workings.
This should help you get it clean.
My goodman furnace, model number GDS80703AXBB has a red light bllinking 4 times and the panel says it means open high limit... how do i fix this?
Hello, a limit switch will open when the furnace gets too hot, the switch senses that the temperature is too hot and shut down the furnace for safety. Uusally a limit switch will open because of lack of airflow across the heat exchanger, this could be due to a dirty air filter, dirty blower wheel, or the blower motor itself is not running at the proper speed. I hope this helps.
2answers
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
JUST SAND THE FLAME SENSOR LOCATED IN FRONT OF THE LAST GAS PORT.
I have an electric furnace...there is no air at all coming from most of the vents located on the out walls and very little air coming out of the vents situated in the center of the house. It is cold in the...
Dirty filters, dirty coils, collapsed duct work, or a fan motor with the blades covered in dirt, dust, mold etc reducingthe airflow.
All of the above could cause your symptoms, clean/have cleaned and check those issues.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
