Question about Philips CDR785 3-Disc CD Recorder
Recording problem Everytime I try to burn a CD it stops in the middle and cuts off. I am using the right blank cd and it happens whether I am trying to burn from a cd or trying to record live. Can someone help me?
  • 112 Answers
Does it stop at the same time elapsed on the CDr every time? Can you resume recording on the same disc afterwards? What about if you dubb high speed from the internal player?
Posted on Jan 15, 2008
My computerwill not read my CD-R as a blank CD, I am trying to burn songs onto the CD-R from iTunes. Help please.
Go into my computer or computer > right click on the cd/dvd rw drive > select properties > go to the recording tab on top > ensure that the Enable CD recording on this device box is checked.
Sep 16, 2010 | Maxell CD-R 80 Minute 700MB Media...
My cd/dvd drive will not burn cd/dvd's properly. it goes through the motions, but the discs come out as blank, i was able to burn cds at 2x speed, but that was it. any movie, or anything else will go...
what kind of application you use for burning??
try it again then double check if you really choose the right path of th drive you want to use as burner..
then you are sure that you burn the music as audio cd not data well as the video cd not data cd..
because if you burn data cd only computers can read that.. not your aplliances like for example your dvd player,cd,etc.
Feb 08, 2010 | Computers & Internet
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
The cd burner on my hp laptop doesn't work properly.
There could be are various reason's for there.
1. The CD you insert is not blank or re-writetable
2. The CD is blank but its not the correct format (CD, DVD)
3. And worse case is the CD Drive is not a burner.
Hope this helps.
Mar 30, 2009 | HP Pavilion dv8000t Notebook
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
How do you burn a cd on the travelmate 290 ?
Windows XP CD Copy Windows XP has CD-Recordable (CD-R) disc burning support for most CD writers.
8b118c9.gif First set your CD-recording options:
  • Open "My Computer"
  • Right-click your CD-R drive and select "Properties". See figure BK-1.
  • Select the "Recording" tab (if this tab isn't available, your device doesn't support CD burning).
  • Check the box to "Enable CD recording on this drive".
  • Select the drive to hold the temporary files (before the system burns a CD-R disc, the system writes the files to be recorded to an intermediary area - this area must have enough free space to hold an entire CD's content).
  • Select the CD recording speed (Fastest, 4X, 2X, and 1X).
  • Select whether to eject the media after recording.
  • Click OK.
Perform the following steps to record to a CD-R:
  • Insert a blank CD-R disc into your CD burner.
  • Copy or drag the files or folders to be recorded to the CD-R drive, or right-click on the files or folders and select Send To, Writable CD.
  • After you have copied all the files, select the CD-R drive from "My Computer" and you'll see the waiting files as "Files to add to the CD."
  • Right-click the CD-R drive, and select Write to CD.
  • Enter a name for the CD-R disc, and click Next.
  • The files will be written to the CD-R disc.
  • After the system writes all the files, it will eject the CD-R disc (if you chose that option above).
  • Click Finish.
Jun 06, 2008 | Acer Computers & Internet
My CD Burner won't detect blank CD.
go to my computer, right click on your cd drive, select properties, at the top select recording, make sure its checked the option "enable cd recording in this drive"
Mar 02, 2008 | Computers & Internet
CD /DVD burner not identifying the disc
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D or E drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 24, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Error: There is no disc in the drive.
This is a common problem I have seen over the years at my lab, it appears that the Laser for the CD, burns out, or the detector for the CD side of things fails..either way it usually results in DVD working 100% BUT the CD side if things is no good... Then ya spen ages going round in circles trying to "Fix" it when there is none, Unfortuanatly it means ya gonna have to get another unit :(
Aug 04, 2007 | Lite On SOHW-1693S (844149001739) DVD±RW...
CD Burner stops in middle of burning
Hi KayGo, People hate going over the basics but gotta ask: -Have you tried cleaning your read/write heads using a commercial cleaner? -Do you have any problems reading CDs? -What Brand of CDs are you using? If you're using the cheapies you should try a few quality brands such as HP or Fugi. -Have you checked the drives manufacturers specifications for blank disks? -What recording speed are you using? Try setting it lower and see if that has any effect. -How much reading and writing have you done with this drive? They do wear out and CD only R/W drives have a history of not lasting long. -Have you tried running a diagnostic on your drive? Here is a link to the Sony CD/DVD diagnostic tool. Meant for Sony drives but I have used this successfully on other drives - Let us know if you need any other assistance and don't forget to rate the posting.
Jan 03, 2007 | LG CED 8120B CD-RW Burner
Philips CDR785 3-Disc CD Recorder Logo
270 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
