Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
For the first time I accidentally dropped my Powerbook from about a foot off the ground and only the side actually impacted with the carpeted floor. It wasn't a strong impact at all however once that happened my airport signal disappeared and the unit doesn't recognize an airport hardware installed anymore. I use the built in airport hardware not an airport card. All my attempts to reacquire the hardware has been futile. Wondering if I need to open the unit up to check for proper connection and how to do it. Thank you.
Henry
  • MellowMickey Feb 16, 2008
    Hi all,
    Same problem here, but with a 12" Powerbook.
    It was switched off when it fell to the carpeted floor from about a foot up.
    When I turned it on all was fine, except it now tells me no Airport Hardware is installed. Will I need to open up the Powerbook as well? If so, will I need to dismantle the entire base or can I just unscrew the small cover next to the battery? And finally, once opened up, is the Airport section clearly marked?
    Thanks very much indeed
    Mike
  • nayr5000 May 31, 2008
    I have the same problem. Airport hardware is not recognized after mac was dropped. How can this be fixed?
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Posted on Oct 03, 2008
    Scholar:
  • 163 Answers
Should be directly under the keyboard and these generally have a retainer that holds them down.. Try reseating it however..
Posted on Jan 15, 2008
Go to ifixit.com it will give step by step instructions for all problems.
Posted on Aug 11, 2008
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
Jan 05, 2013 | Apple PowerBook G4 Mac Notebook
Display won't turn back on
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Hope that helps...........
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I have an old PowerBook g4 in my kitchen for listening to pandora and looking up recipes. All of a sudden, the wifi stopped working. It has dropped out a few times before, but I have always been able to...
Cut the airport off and back on again. After that, delete any wifi profiles you have, and then re-add them. This will clear any corrupt profiles and troubleshoot that. If you can't connect to anything after that, check that the airport card is connected securely. If, after all that, it still isn't working, and other devices are able to connect to the same network, then your airport card is probably no longer working.
Nov 09, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
Trouble downloading songs from G-3 I phone to powerbook g4
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
If you are experiencing issues with downloading songs from iPhone 3G to your Powerbook G4, there are a few steps you need to check:
Make sure your Mac OS X operating system version is up to date. The most current updates for the current 3 most common Mac OS systems out today: Mac OS X 10.4 Tiger: Mac OS X 10.4.11 (Current version) Mac OS X 10.5 Leopard: Mac OS X 10.5.8 (Current version) Mac OS X 10.6 Snow Leopard: Mac OS X 10.6.6 (Current version)
If your present version of Mac OS X does not match the current version update listed above for your system, then click on the Apple menu icon in the upper left corner of your screen and select "About this Mac" to verify. • Then close that window and click on the Apple menu icon once again and select Software Updates andrun the updates.
• Once your Mac OS X has been updated to the most current version, then you will need to visit the link below, then download and install the current version iTunes Link: Download iTunes 10 for Mac (for 10.5 Leopard or higher) Link: Download iTunes 9.2.1 for Mac (for Mac OS X 10.4 Tiger or earlier)
• When you have the current version of iTunes on your Powerbook, then commence to connect your iPhone 3G with your Powerbook and sync your iPhone with iTunes.
I am providing these initial steps to you, due to the limited information I have from you regarding your technical issue, but will be glad to assist you further, if you are unable to resolve your issue with these provided steps.
I hope this helps.
Regards,
-Mactectrainer
Jan 30, 2011 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
How do I connect to the internet via WIFI with a MAC Powerbook G3 laptop?
The easiest way if your Powerbook doesn't come equipped with an Airport card or isn't capable of supporting an Airport card is to purchase this http://www.sonnettech.com/product/aria_extreme.html it slides into the PCMIA slot on your Powerbook G3 (the credit card sized slot on the side of your Powerbook G3). There's support issues and model variations on older Powerbook G3's regarding Airport Card support and they're not as readily available as a standard PCMIA wireless card. This is my best suggestion for your situation.
Jun 01, 2010 | Apple PowerBook G3 Mac Notebook
Cant install so 10.2 onto powerbook g4.
Remove both RAM chips and re-insert, because sometimes they come loose. Now give it a shot old chap. Also, your RAM chips may have died, so insert new ones and give it a shot.
Don't install Panther 10.2, because that operating system (OS) is too old. The PowerBook runs best with the Tiger 10.4 OS. You need to install a retail version disc with black label instead of a gray label disc, because those discs are computer specific to certain models only.
Cheers
Jan 24, 2010 | Apple PowerBook G4 Mac Notebook
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Airport Express, Bonjour Printing Does Work With Leopard
In the setup of the Airport network settings, you have to make sure that AppleTalk is actually turned on (or the box is checked). When using Mac's with Leopard and you use both the ethernet port and airport off and on, the OS tends to deactivate AppleTalk. Its not a set thing, just random.
Jun 27, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I say it'd be more likely that the airport card shifted in the socket. I could be wrong but take a look. I'm not sure if it's true on the 12" models, but on all the others, there is a cover in the battery compartment that hides the airport. Take it out and put it back in. My 17" powerbook took a 4ft drop to the asphalt late last year and it came out with only a few small scratches. You might also try swapping the airport card with another one just to verify if the slot is good.
May 31, 2008 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
1,331 people viewed this question
David Payne
David Payne
