Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hard drive crashes in windows explorer when i
Hard drive crashes in windows explorer when i open a folder. ran chkdsk and defrag on hard drive
    Problem Solver:
  • 16 Answers
Firstly check for virus before opening a anything, secondly these particular HDDs are notorious for overheating so it could be that yours is about to die. i think earlier models also came with the option to connect to the pc via usb2, have you tried that if possible?
Posted on Nov 22, 2009
Cannot recover data from dell latitude d610 hard drive
Try removing the hard drive and connecting it to ab USN hard drive adapter, then plug this USB adapter and hard drive into the USB port of a working computer.
If this computer can see this as an external storage device and if you are lucky you can open the various folders and files then you can back up your data.
I think this hard drive has failed completely, there are companies that can recover data from faulty hard drives BUT it will cose you an arm and a leg for their services.
Feb 13, 2012 | Dell Latitude D600 Notebook
Tip
Hard Drive Basics and Beyond Part2
The list is as follows
As of 2010, virtually all of the world's Hard Disk Drives are manufactured by just five large companies: Seagate, Western Digital, Hitachi, Samsung, and Toshiba.
Now to the Fun Stuff
Whether we are building our own computer, upgrading our existing PC or just adding an extra hard drive to increase storage, we usually rely entirely on Windows for maintenance and care of this new or old hard drive. That's not always as efficient or good as it sounds. If you have ever used the Windows defragment software to defrag your hard drive, you know just how tedious and long this process is. The Defrag program itself is not very intuitive and has very few adjustable parameters.
Defragmenting is good!
It is usually a good idea to download a non Windows defragmenter with more user friendly options such as quick defrag, data map (for seeing what chunks of data are being moved) or selectable defragment options which allow you to choose what to defragment. What you select as your program of choice is entirely up to you. Be advised, however. Microsoft has been
steadily working you away from having any control over how you
defragment your drive.
With each upgrade and revision of Windows, you see less and less of what is actually going on with your hard drive, which places all of your trust on a company most people know very little about.
If you are like me, your hardware is important to you, and you want to know more, not less about what may be going wrong with your equipment. Why defrag doesn't automatically run when your hard drive slows down due to severe fragmentation is a mystery I have never solved.
Your antivirus will stop a program from destroying data, your Desktop has an automatic cleanup wizard, and even your Email asks if you want to compact messages to save space. So why does Windows allow your hard drive to fragment itself to such a state that data loss can occur simply
because Windows can no longer remember where your files are stored?
Well, those problems won't be solved by wishful thinking, we have to take control and do this ourselves. Some good defragment programs will have a scheduler, and you will want to set this up to run at a time when you will not be busy on your PC. Remember to disable screensavers as this will slow down your defrag speed. Some antiviruses can do this as well, especially if they just happen to update you while the defragmenter is running. Essentially Any program that writes data to your hard drive while you are trying to defrag it will slow down your completion time, so turn it off.
Scandisk or Checkdisk
CHKDSK (short for Checkdisk) is a command on computers running DOS, OS/2 and Microsoft Windows operating systems that displays the file system integrity status of hard disks and floppy disk and can fix logical file system errors. It is similar to the fsck command in Unix.
On computers running NT-based versions of Windows, CHKDSK can also check the disk surface for physical errors or bad sectors, (an area of the disk that may have had a momentary head
crash) a task previously done by SCANDISK (for older versions of Windows such as, 95,98,ME).
This version of CHKDSK can also handle some physical errors and recover data that is still readable.
When do you run scandisk?
1. When data loss has occurred, typically when Windows cannot find a file.
2. When your computer can actually find the file, but takes forever getting there.
3. When your PC is using a hibernation file as well as system restore and cant restore properly.
4. When your PC continually starts up in safe mode.
5. When you get an error stating that Windows must shut down to prevent data loss.
6. After a virus is detected and cleaned.
Windows does not perform this check automatically or when an error occurs. In some instances such as several hard starts or crashes, Windows will offer to run the scandisk or start itself, but by then it is usually too late to actually do any good. While it may make you feel better that the Disk check program has started on it's own, and it appears that Windows is trying to protect you from data loss, the actual fact is that this is a last ditch effort for Windows to recover itself, not your data, but it's own startup files. If your data gets saved in the process, so much the better.
Alternately you can run Scandisk-Checkdisk in the Shell mode or dos type box.
CHKDSK can be run from the Windows Shell, the Windows Command Prompt or the Windows Recovery Console. One option for CHKDSK is the use of the Command-line/R parameter, which allows the program to repair damage it finds on the hard drive.
Conducting a CHKDSK can take some time, especially if using the /R parameter, and the results are often not visible, for various reasons. The results of a CHKDSK conducted on restart using Windows 2000 or later operating systems are written to the Application Log, with a "Source"
name of Wininit or Winlogon and can be viewed with the Event Viewer.
This method is usually your last line of defense and will only be offered in extreme situations where a boot failure has occurred.
A word on SFC (System File Checker)
Have you ever had a program fail to execute, then follow with a DLL error of some type? This is a handy way to restore that corrupt, missing or virus altered DLL, and it can be started in Windows.
By default, Windows File Protection is always enabled and allows Windows digitally signed files to replace existing files safely. Currently, signed files are distributed through:
# Windows Service Packs
# Hotfix distributions
# Operating system upgrades
# Windows Update
# Windows Device Manager
If you introduce a file replacement in any other way, Windows File protection will overwrite your file! An important part of Windows File Protection is the command line utility:
System File Checker (sfc.exe)
Use this utility when you suspect there may be a problem with a Windows XP system file. To do this simply go to the Run box on the Start Menu and type in: sfc /scannow.
on Mar 16, 2010 | Computers & Internet
Tip
10 reasons why PCs crash-You must know tip 4
4 Hard disk drives
After a few weeks, the information on a hard disk drive starts to become piecemeal or fragmented. It is a good idea to defragment the hard disk every week or so, to prevent the disk from causing a screen freeze. Go to
* Start-Programs-Accessories-System Tools-Disk Defragmenter
This will start the procedure. You will be unable to write data to the hard drive (to save it) while the disk is defragmenting, so it is a good idea to schedule the procedure for a period of inactivity using the Task Scheduler.
The Task Scheduler should be one of the small icons on the bottom right of the Windows opening page (the desktop).
Some lockups and screen freezes caused by hard disk problems can be solved by reducing the read-ahead optimisation. This can be adjusted by going to
* Start-Settings-Control Panel-System Icon-Performance-File System-Hard Disk.
Hard disks will slow down and crash if they are too full. Do some housekeeping on your hard drive every few months and free some space on it. Open the Windows folder on the C drive and find the Temporary Internet Files folder. Deleting the contents (not the folder) can free a lot of space.
Empty the Recycle Bin every week to free more space. Hard disk drives should be scanned every week for errors or bad sectors. Go to
* Start-Programs-Accessories-System Tools-ScanDisk
Otherwise assign the Task Scheduler to perform this operation at night when the computer is not in use.
on Mar 04, 2010 | Computers & Internet
Hard drive enclosure does not show files on hd. empty folder but preferences shows 27 folders
most likely your hard drive or corupt .. do defrag defrag software on the internet looking for a free or paid. corupt hard drive crashes and makes your software does not run properly
Jul 26, 2011 | Computers & Internet
Program crashed whe click on 'get' then 'computer'
I think your temp folders are full and your drive is diffragmented and could be full.
so first empty all the temp file you have and deleate all the cookies ,recent files and prefetch folder in windows directory and you cand delete the cookies and temp internet files from your explorer tools and internet option delite all files .
then run the disk difragment from right click on the hard drive go to properties and then tools and defragment volume and analyge volume and then defragment .so your system is cool and clean and the cache directories will be empty and will work fine.
Dec 12, 2010 | Computers & Internet
When I try to defrag my hard drive, I get a message which says "disk defragmenter could not open".
Possible Solutions:
1. Turn page file on.
Turning the page file on is a relatively simple process. Begin by selecting Start and right-clicking My Computer. Choose Properties and then press the Advanced tab. Next, choose the Settings button that is located in the Performance area; choose the Advanced tab in this area, and then press the Change button that is found in the Virtual Memory area. There will be a choice called System Managed Size in the Virtual Memory area, select it, press Set (this one is important), and then choose OK. The final move is the most important one; at this point you need to restart the PC. After you finish following these directions Disk Defragmenter should be available to do its magic.
2. Re-register the defragmenters snap-in files
It is possible that you install a third-party defragmenter like Diskeeper, then on uninstalling, it does not restore the built-in one correctly. Open Command Prompt (good ol' DOS) by clicking Start -> All Programs -> Accessories -> Command Prompt. At the command prompt type,
cd \windows\system32And then register the defrag components, by typing:
regsvr32 dfrgsnap.dll
regsvr32 dfrgui.dll
At this stage, you may find the disc defragmenter works. If not, there is one more step you can do.
Using Windows Explorer browse to your windows\inf folder.
In there you will find a file called dfrg.inf right click this file, and select Install.
3. Check if you have enough free space on the drive you want to defrag. It should have at least 15% free space.
A volume must have at least 15% free space for defrag to completely and adequately defragment it. Defrag uses this space as a sorting area for file fragments. If a volume has less than 15% free space, defrag will only partially defragment it. To increase the free space on a volume, delete unneeded files or move them to another disk.
4. Run CHKDSK on the volume first before defragmenting.
To run chkdsk on a volume (partition, disk), go to Windows Explorer (not to be confused with Internet Explorer) -> right click the partition -> Properties -> Tools tab -> Check now -> place check marks as required -> Start
5. Check if you have the appropriate services running.
Start > run > services.msc [enter]
Browse down to these services and see if appropriate settings was set.
Logical disk manager - automatic
Logical disk manager administrative service - manual or automatic
Defrag with XP also needs the DCOM Server Process Launcher service running.
6. Your computer might have spyware or malware. Some viruses/malware are known to interrupt/disable system tools such as disc defragmenter. Try to download and run No Adware (download here), an anti-spyware and adware tool. You can also use Malwarebytes Anti-Malware tool or Smitfraudfix (how to use smitfraudfix?) to remove spywares or malwares that are running on your system.
7. Install and run third-party disk defragmenting software.
8. If all of the above possible solutions fail. I'm afraid you need to repair install your OS or as a last resort, reformat your computer (but yeah, I know, nobody want to do that just because of disk defragmenter).
Jul 08, 2010 | Microsoft Windows XP Home Edition
Windows XP system - explorer crashes
Need way more data for this. First, how much free space on hard drive? Empty all temp files and run clean up/defrag
Dec 28, 2008 | Computers & Internet
Can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Dec 27, 2008 | Western Digital Passport WDXML800UE...
External USB drive making clicking noise - Windows does not recognize it!
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
May 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
SimpleTech 500GB Hi-Speed USB 2.0 causing Windows to crash
Blue screen means hardware problem, Try to defrag your hardware possible bad sector problem. Just follow the procedure as follow: Click Start> Programs>Accessories>Disk Deframenter.
After opening fragment's system select the drive by highlighted the available drive and click defragment button. Just wait until done. It will automatically fix the bad sector if not so critical.
If the problem persist during the defragment, there is a critical problem with your harddrive.
Please rate me SOLVED
Nov 21, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
217 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
