Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
Burning Smell A electrical burning smell was coming from behind the frezer. Unplugged it and smell went away. Wondering what I should replace first. The freezer was working ok at the time.
  • 63 Answers
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Posted on Jan 28, 2008
Strong Odor when running
The smell is coming from the condenser heating up which should be located all around the outside of the box. When it is in pull down from being warm the condenser will get very hot and the smell would be the spray foam and any other chemicals in the vicinity heating up. When heated up to a certain point they will off gas and you may get a smell. After a little wile the smell should go away for good.
Mar 27, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Cause for burning smell from lower back of upright freezer
your freezer might be having blockage on the drain pipe thus not allowing water to flow on the drain tray if the drain tray is mounted on the compressor and its dry then the compressor or the condensor pipes are burning the drain tray. the solution to this problem is to service your freezer
Jan 23, 2013 | GE Freezers
My chest freezer (a Kelvinator) runs, but does not get cold. The motor is clearly trying to run, but does not lower the temp beyond room temperature. There is a vague smell of burning when I leave it...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 09, 2010 | GE 13.7 cu. ft. General Electric Upright...
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
Burning smell in freezer
defrost heater may be melting wiring or plastic parts during defrost.
Aug 13, 2009 | Freezers
Burning smell coming from front door selection , compartment for ice and cold water .When lifting up grey pad area which you press to dispence the water and ice , behind is black and burnt
You have a clear and present fire hazard that should be looked at ASAP. Do not leave this appliance unattended and you should unplug it any time you are away from it until professional repair arrives.
Good Luck.
Aug 12, 2009 | Maytag Freezers
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer smells like something is burning
there is a heater inside hte freezer compartment of any self defrost unit. the heate might have just been on and some debris fell across it. might be worth to have someone come out and look for a service, why chance it.
Mar 18, 2008 | Freezers
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
548 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
