Question about Technics SA-DA8 Receiver
Sa-Da8 Overload and power off
Hi, i have a Sa-Da8 and when i listen to music more than 45%, overload came on and the amp came off. No wire are touching, nothing visual to. Do you have suggestion?????thanks
  • 86 Answers
You mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Posted on Oct 22, 2008
Its it's a Panasonic receiver sa - xr15 it keeps on saying it's overloaded and I got nothing hooked up to it right now
It might be down to the fact that the main power amp has shorted and therefore overloading the system. It can happen if say you had some faulty speaker cable, or two wires touched together. Or it can happen on it's own.
May 14, 2016 | Panasonic Audio Players & Recorders
Tip
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
on Nov 05, 2011 | Technics SA-DA8 Receiver
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
My amp says overload whenever i plug speakers in to it. its a Technics SA-DA20
Check your wiring. Make certain there's no breaks and the two parts of the cable do not touch each other.
If it still says the same with good wiring you have probably developed a fault in the main amp. A failed transistor etc, located on the big heat sink.
Oct 03, 2013 | Technics Audio Players & Recorders
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
How do you download music
Hi Finch,
Try these links:
http://www.google.com/#hl=en&safe=off&pwst=1&&sa=X&ei=SlsWTcelFcH7lwflqsm6Cw&ved=0CCIQvwUoAQ&q=Download+music+free&spell=1&fp=9bef8cda26d1a6ec
You can listen to just about anyone at WWW.GroveShark.com
And here you can findthe top 50 music search engines:
http://www.addictivetips.com/internet-tips/top-50-music-search-engines-start-listening-now/
Hope that helps
Dec 25, 2010 | Computers & Internet
SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Oct 22, 2008 | Technics SA-DA8 Receiver
Sa-da8 overload and off
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Jan 21, 2008 | Technics SA-DA8 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
Technics SA-DA8 Receiver Logo
514 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
