Question about Jenn-Air JFC2087HRS Side by Side Refrigerator
Defrost cycle staying on?
Fridge and Freezer go into defrost but don’t seem to come back to cooling unless I turn the temperature switches at the top of the fridge cavity off and back on again. With a wireless thermometer in the freezer, I saw the temp go from 0° to 27° and the fridge go from 34° to 42° before opening the door and doing this.
How often should the unit go into defrost? Every 7 days?
What part would be defective if it is not restarting its cool cycle?
  • Eaglehorse6 Apr 21, 2008
    Twice now, our 3-year old Jenn-Air French Door refrigerator has gone into the full-time defrost mode -- which ends up with the compressor running all the time and frost on the back wall of the freezer, with the coils completely blocked with ice/frost. Each time the solution has been to replace the control board (part no. 67006740 or Whirlpool part no. W10165748). The part costs about $75 retail, but the total repair bill costs 3 or 4 times that much. Apparently we can look forward to replacing the control board every 18 months. Is there anything we can do to extend its life?
SOURCE: Freezer working Fridge NOT COOLING
fridge takes its coldnest from the freezer check if the fan is running or if the vent is close
Posted on May 13, 2007
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Posted on Jun 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Posted on Jul 01, 2009
mgprice
  • 744 Answers
SOURCE: the freezer element build up with ice and the
Hi, With the information you supplied I’m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Posted on Oct 17, 2009
Testimonial: "UNFORTUNETLY THIS DID NOT PERTAIN TO MY MODEL SO I COULD NOT USE THE INFORMATION"
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
The temperature in the refrigerator is staying at 77 and the freezer is staying at 65. The top of bothe the fridge and the freezer seem to not be getting any cold air, ut the condenser fan is working, and...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jun 16, 2011 | Frigidaire Gallery GLHS66EJSB Stainless...
I have a Westinghouse frostfree rj25m upright fridge/freezer. The freezer is working fine but the refrigerator won't cool. I want to fix it myself as it is an old fridge and really not worth spending $300...
I am not sure if your freezer is working correctly if the fridge compartment is not at the right temperature. The way refrigerators work is that the fridge compartment is indirectly cooled by the freezer. The evaporator coils that cool the freezer, also cool the refrigerator. There is a fan in the freezer section that draws air from the refrigerator and blow them over the coils. The vent to the refrigerator could be blocked by debris or ice build up if the defrost circuit has failed. In order to check, you need to remove the back panel from the freezer section to check the condition of the coils/vent. Also check the fan in the freezer and see if it is operating. If the coil is encased in ice, then the defrost circuit has failed and that needs to be fixed otherwise the freezer will not cool to the correct temperature.
The way the defrost circuit worksis that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Mar 13, 2011 | Refrigerators
FREEZER GETS COLD BUT BOTTOM DOES NOT
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 23, 2011 | GE GTS22KBP Top Freezer Refrigerator
I found the refrigerator not cooling. I unplugged the unit, vacuumed the coils, plugged unit back in. The unit began to cool and kept it's temperature for 18 hours. I then noticed it began to cool back...
DEFROST PROBLEM
Dec 26, 2010 | GE Profile PTS22LCSCC 33" 21.7 Cu. Ft....
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer working fine, but no cold air to fridge
  • possible causes:
  1. bad defrost timer/control unit
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Freezer stays cold, but not fridge
i had the same proble open freezer door and unscrew back plate if coils are iced up its eather a sensor on tot or the heaters lond tubes you can see if all iced up get blow dryer out to defrost
Aug 14, 2007 | Frigidaire FRT21P5A Top Freezer...
Jenn-Air JFC2087HRS Side by Side Refrigerator Logo
95 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
