Question about LG WM-2277HW Front Load Washer
Change water settings
I need to know how to change the water settings from warm/cold to default cold/cold, cannot find my manual.
Thanks.
    President:
  • 1,294 Answers
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 13, 2008
Installing a Miele WS5425 cold water fill only?
if you only want cold water for washing, just select cold wash in the program settings and turn off the hot water tap
so the settings you will be looking at are --like --
tub fill ---low water medium water or high water
water temp cold or hot
rinse hot or cold , wash setting --heavy , delicates , whites , woollens etc
may not be exactly worded like that but you get the idea
when ever you see wash temp or water temp , select-- cold
Jul 08, 2017 | Dishwashers
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
I bought this washer used with out a manuel. I
Hello-I came across this several years ago. Some whirlpools have a preprogram where the water temp. is already defaulted to the type of load and color. As you assume the white should be hot or warm. The rest of the selections are probably cold. The manufactures can be driven to apply energy saving features into their products so most cycles are probably cold. If all else fails, when you make a selection let water fill into the tub about 5 minutes and carefully check to see if the water is warmer or colder. You also might be able to pull up owners info on the net if you have the model#.
Feb 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Water is not hot enough
What a great energy saver response....run water through another tap in the house in order to fill the pipes with hot water! I have the same problem; cannot even get WARM water in my tub. I have 2 solutions: #1, on my incoming water pipes are regular faucet handles which I am going to attach a hose on the hot side that will reach into the washer and manually mix the temperature. #2, purchase an old refurb washer at a used appliance store that HAS a hot-water setting and hope they will take the "wonderful, new energy saver" as a trade. There are just some times you really need HOT water. I can't imagine washing diapers in cold, although I haven't had to do that in many years. Energy saving factory settings: capital "B", capital "S"!!!
Mar 30, 2009 | Washing Machines
Our GE washer WASE5210B3WW will only go in the rinse and final spin cycle when turned on.
HI THANKS FOR YOUR QUESTION ,wHEN YOU SELECT nORMAL WASH dOESWATER COME IN. IF NO LOOK AT THE WAETER TEM SETTINGS YOU HAVE SELECTED iF THE WATER TEMP SELECTOR IS SET FOR HOT AND NO WATER CHANGE THE WATER TEMP TO WARM IF COLD ONLY COMES IN YOU NEED A WATER VALVE .tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Sep 12, 2008 | Washing Machines
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Jun 10, 2008 | HP LaserJet P2015dn Printer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
LG WM-2277HW Front Load Washer Logo
177 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
