Computers & Internet Logo
Posted on Nov 22, 2009
How to keep turboc in fullscreen in windows-7
Anonymous
Level 1:
Novelist:
  • Contributor 106 Answers
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
Novelist:
Answers
106
Questions
0
Helped
38074
Points
Windows 7 doesnt support fullscreen. You can still use the tweak to get it working. Follow the below link
http://computrgeek.wordpress.com/2009/04/22/full-screen-mode-for-turbo-c-on-vista/
  • asktechisle Dec 31, 2010
    Tech Islehttp://techisle.110mb.com/
    Download Emulated Turbo C (it will work in full screen in windows 7 or vista)
    If u want to use QBasic Contact Admin of website...I am sure he will help....
mehul
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Aug 21, 2012
mehul
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
7008
Points
10
2helpful
3answers
How do I download free Netflix app to my laptop using windows 7?
Windows 7 does not have apps like Windows 8. The best thing you can do is log into http://www.netflix.com/ and stream in fullscreen mode.
Feb 14, 2015 • Netflix
My c++ is not working in fullscreen in my win7
I think you have an old C++ complier like Turboc,etc.
Win7 has this awesome feature where you can run old apps in Old Windows modes. Just right click on the C++ app file and select troubleshoot compatability and follow the wizard which will guide you through the process.
5helpful
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
How to create a network between 2 computers
The image you posted is too small for viewing. However, Turbo C++ is an old, old, old program, it's no wonder it doesn't work on a 64-bit OS. You probably need to run it in the virtual XP mode.
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
2answers
Hp laptop,,vista os,,turboc not working in full screen
In order to get the full screen use the key combination of Alt and Enter
If you right click on program, in properties,you'll see an option called program compatibility. Make compatible with earlier versions
3helpful
3answers
Turboc not working on asus m2n-mx motherboard
Right click on tc.exe click on screen tab check out window instead of full screen under usage options.TC will run in window mode.Then press Alt+Enter to fullscreen.
No solution yet for c graphics programs crash on nvidia chipset.(yeah problem is in nvidia chipset not in MoBo).
2answers
C++
If it says that your system can not run it in fullscreen mode, then it certainly can not be ran in fullscreen mode.
~Actaviosan
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
