Question about Dream'eo PVP E320 (20 GB) Digital Media Player
Dreameo PVP E320 GPS problem
I have PVP E320, The problem with the device is that the GPS doesn't work now(after 1yr). It has a external GPS card (Holux), normally if the GPS port is detected the lead light keeps blinking. These days the light is always solid red and also when I activate GPS, the word 'GPS' doesn't turn green from Red, thus no GPS system is working, I did a GPS diagnosis provided within system, it also says no GPS is detected.
Any Idea if anyone has a fix for this.
My tom tom has a flashing x? How can I fix that?
It is possible that the (internal or external SD card) storage holding the map data(base) and/or the navigation software is corrupted.
Have you tried running a (fix) disk utility against your (internal or external) storage disk for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
Running this (Windows) utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 21, 2013 | Tomtom GPS
How do you reset garmin nuvi 650 gps
Turn it off and on again. If this doesn't do it, do the following.
Disconnect the unit from external power. Flip up the antenna and press the RESET button. Connect the unit to the external power source. The unit should turn on and operate normally.
The above is from page 34 of the manual.
Mar 08, 2012 | Garmin GPS
It doesn't have the SD card in it...does that matter?
Probably not ... you can add one if your like ... but the device will operate just fine without one.
Sep 05, 2011 | LG LN730 GPS Receiver
Has been charged, but has no power, will not turn on.
mine did that aswell.checked out n tried solutions on this n other sites with no luck.i eventually just opened it to check the battery(unit 1yr old).batt was fine.when i put it all back together it works fine.assume that disconnecting battery is the mysterious reset button.hope this helps
Oct 14, 2010 | Garmin Nuvi 255 GPS Receiver
My tomtom go 300 will not work.no gps device showes on device
hi, looks to me if you have no sats recveived. try to go online with tomtomhome program an download the latest quickgpsfix file. also try if it works better when you are outside. a heat protective coating can disturb the antenna, then you will need an external antenna. good luck and if its still not working proper, you can always ask for more options. greetings
Feb 17, 2010 | Tomtom GO 300 GPS Receiver
Hi, have my gps garmin nuvi 350 i losse my memory card , i buy new one , i wan free sofware download dirction trafic in my new memory card
You have to purchase the external traffic receiver that plugs into your side mini-USB port in order to receive traffic information. This is not possible on a SD card.
- Jim
SHARCNET-USA
Jan 02, 2010 | Garmin nuvi 350 GPS Receiver
My Nuvi255 will only work on external power (cigarette lighter) almost like there is no internal battery installed
Have you tried charging this through other sources such as a usb or ac charger (please ensure the unit is off when attached to power to enter charge mode) as it may be the cable itself faulty, if it still doesn;t hold charge then the unit is faulty and should be returned to your local store
Oct 15, 2009 | Garmin Nuvi 255 GPS Receiver
Sandisk 4G HC DOESN T WORK IN MY GPS AND IN EASYSHARE KODAK
Check to see from the manufacturer if there is a firmware update that may enable you to use SDHC cards. If there isn't you might be out of luck.
The cameras that take SD cards are sometimes older and not able to be upgraded to take SDHC cards.
Jul 20, 2008 | Cameras
Fine Drive 400 Software/Maps
> How do I get it to go to Louisiana?
You internal GPS antenna does not work.
Buy an external GPS antenna for FD400
on eBay $10+$10 shipping = $20
Jan 19, 2008 | GPS
Dream'eo PVP E320 (20 GB) Digital Media Player Logo
89 people viewed this question
Top Dream'eo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dream'eo Audio Player and Recorder Expert? Answer questions, earn points and help others
