The brush is driven by two belts and a clutch. Your belts on the clutch are stretched. Their are several youtube videos for rebuilding and replacing a DC07 clutch. Just change the blets don't buy a new clutch. A lot cheaper to change belts. You might as well clean everything up while you gave it apart. Have fun.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, if your brush bar isn't turning then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look at www.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look at www.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer.
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking.Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch.New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look at www.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer.
DC14s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available oneBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07 which is very similiar to your DC 14, but unless you haveaccessto such tools, and feel confident to tackle it, it's probably time tocallDyson or aVacuumrepairer.
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available oneBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you haveaccessto such tools, and feel confident to tackle it, it's probably time tocallDyson or aVacuumrepairer.
This model has Brush Control The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
