Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
USB CONNECT ONE FOR POWER+DATA ? AND THE OTHER POWER ONLY?
I have a Dell Inspiron 8600 with 2 USB ports. How do I connect the Maxtor into the correct USB ports. I am having a power surge.
  • 77 Answers
It sounds like your USB ports just aren't putting out enough power for this device. Did the drive come with an external power supply? If so, does it work when you use the external power supply?
Posted on Jan 19, 2008
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
USB recognition
Hello here is your pc`s homepage:
http://www.dell.com/support/drivers/us/en/04/Product/inspiron-8600
First check for any drivers missing in the device manager.
You need to install itunes to communicate with the ipod and ipad:
http://www.apple.com/itunes/download/
If you have an old itunes, uninstall it and install the new.
Good luck
Jan 10, 2013 | Dell Inspiron 8600 Notebook
USB port on laptop is not working
make sure the driver is installed
Jan 03, 2010 | Dell Inspiron 8600 Notebook
I have an Inspiron 8600 the usb ports have stopped working. I've done all of the stuff it tells you to do on Dell's support site but nothing is working. What should I do next?
go to BIOS set up if there wrong with it..
see to it if the USB port are enabled..
if doesn't enabled it...
then save what your doing in BIos set up...
Oct 23, 2009 | Dell Inspiron 8600 Notebook
Can't connect to internet after reinstalling window-inspiron 8600
Use a computer that is connected to the Internet, then download and copy the drivers on to a CD or USB menory stick and install them on your computer.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link :- http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jun 21, 2009 | Dell Inspiron 8600 Notebook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
Vista won't read Maxtor N256 HD as through USB-IDE cable
So donot take any action to your Maxtor and Try to find a DR company and recovery the data.Maybe the firmware is having some problems.Usually the tools called HD Doctor from SalvationDATA can deal with the firmware problems.
May 18, 2009 | Maxtor Hard Drive
Ethernet port not reading my modem for my dell inspiron 8600
make sure that your tcp/ip networking is set to 'Obtain IP address automatically'.
Power modem first , then laptop. Make sure that you are using the right cable for connection between modem and comp.
Mar 12, 2009 | Dell Inspiron 8600 Notebook
USB port malfunction
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Dec 07, 2008 | Dell Inspiron 8600 Notebook
Driver for Maxtor 71336A
Vista ULTIMATE has all driver incudes!So you dont need extra driver for ur MaXTOR!Just make sure ur OS runin OK and run UPDATE
Dec 28, 2007 | Maxtor Hard Drive
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
141 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
