Question about HP LaserJet 3380 All-In-One Printer
Installed hp laserjet 3380 on apple desktop pro - message printer stopped
I installed laserjet 3380 on a apple desktop pro. Leopard operating system. Every time I try to print, I receive a message "printer stopped" Any suggestions?
See if it is the right driver. Intel Mac is not the same driver set as regular Mac.
Also, Apple + HP or Okidata often = issues.
Posted on Jun 11, 2008
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
I am Using Windows 7 Pro 32-bit OS . when i connect HP laserjet 3380 printer with my pc the USB is not detected also I want to know the full procedure of installation of drivers on windows 7. please...
The printer driver is available through the Windows 7 operating system and does not need to be downloaded from the HP web site.
Check this help link how to install your Printers drivers @ hp support "Install printer on a direct connection"
Hope it helps.
Jun 14, 2011 | HP LaserJet 3380 All-In-One Printer
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Need MAC Snow Leopard printer drivers for;
I had installed the Mac X snow leopard, but every time i tried to print with mi HP laserjet P1005 i have this error
P1005 i have this error Process: PrintJobMgr [416]
Path: /System/Library/Printers/Libraries/PrintJobMgr/Contents/MacOS/PrintJobMgr
Identifier: PrintJobMgr
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: cupsd [28]
I reinstalled the Hp drivers that I could find on the internet but the problem persist
Aug 31, 2009 | Apple Computers & Internet
Hp laserjet 3380
did it work before??
if it did, then your printer has been damaged due to a surge in your phone line
Feb 03, 2009 | HP LaserJet 3380 All-In-One Printer
Printer problem
You need to reset your firmware. You need to call HP care center.
Thanks
Aug 16, 2008 | HP LaserJet 3380 All-In-One Printer
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 3380 All-In-One Printer Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
