Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher 665.15895793
Quick rinse light is blinking. Other controls unresponsive. Any ideas?
  • 413 Answers
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Posted on Jun 02, 2008
Quick rinse light blinking
Quick Rinse light blinking is usually a short in the control panel membrane. Replace the control panel (The outer part, not the control board inside)
Aug 26, 2014 | Kenmore Dishwashers
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Nov 13, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
183 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
