Question about Panasonic DMR-E55 DVD Recorder
Hello, my DMR-E55 DVD Recorder is approx 4 years old and recently the digital display does not show and it will not record on any disc when i try to record it says 'read only' or 'error', please can you help?
Thank you for your time,
Miss Liz Thomas
  • Anonymous Jan 24, 2008
    I have the same problem. If you receive any hint, Please let me know. I would really appreciate it.
    lou711@hotmail.com
  • 185 Answers
Hi Liz
The majority of problems with this particular model are associated with the power board. The drive unit is unlikely to be faulty. Do not risk further damage by immediately trying lense cleaning as suggested by some. The lense will very rarely require cleaning.
The power board can be repaired if you have some technical ability. I have posted full instructions on Fixya on how to do this but you would need to be able to use a soldering iron. These are good units that can usually be restored, so it would be a pity to throw it out for such a fault,
Posted on Feb 03, 2008
Panasonic DMR-E55 DVD Recorder plays does not record
Are you trying to record from a broadcast signal, or via one of the SCART inputs? The E55 has an analogue tuner. If the TV companies in your part of the world have switched to digital broadcasting, the E55 can ONLY be used to record via the SCART and other video inputs, the tuner won't receive anything
Dec 18, 2014 | Panasonic DMR-E55 DVD Recorder
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
Recorder records for approx 1 min the self checks
are you using dvd r or dvd rw discs ?? the r disc cause less of a hassle i have been told hope this helps regards Jim
May 04, 2009 | Panasonic DMR-E55 DVD Recorder
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E55 Won't record AT&T U-Verse programs!
Make sure you only use the correct type of discs: DVD-RAM or DVD-R for recording and DVD-RAM, DVD-R, DVD-Video, DVD-Audio, Video CD, CD-Audio (CD-DA) and CD-R/RW (MP3, CD-DA, Video CD formatted discs) for playback.
DVD-RAM disks are in plentiful supply on eBay, both new and used. Keep an eye open and you should pick them up, new, for less than £1 Sterling each!
I am unclear, though, what you mean about recording to and from the VCR. The DMR-E55 doesn't have a VCR facility, just DVD.
Jan 26, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Problem
I have been told that panasonic now have a faster speed disc on sale to suit the newer dvd recorders that dmr-e55 cannot record on as they are too fast. You have to buy the slower speed ram discs to suit the dmr-e55.
Aug 26, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
