Question about Nokia N95 Cellular Phone
N93 problem when my friend send me video thru bluetooth it hangs up.i remove the battery, when i turn it on its only a white screen that appears.how to fix it? do i have to reboot it? how? please help experts. many many thanks.
    Sniper:
  • 70 Answers
Format ur phone using code * + 3 + Call key + On/Off key till Formatting appear, otherwise u have to Flash ur phone
Posted on Jan 13, 2008
    President:
  • 1,017 Answers
Make sure to always switch off your phone by pressing the On/Off switch.
Before receiving or sending files via bluetooth, press the menu button for 2 seconds, this will show you how many applications are in use, press C to switch them off, (except bluetooth).
Check that your phone memory isn't over full with pics, videos etc...
You could try a reset input:
*#7780# Restores factory settings.
Posted on Jan 12, 2008
My phone is not turning on
Hello My Dear Friend:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 26, 2012 | MOBILESW Alcatel OT-906 2.8" Resistive...
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Acer Aspire One D255-2670
Hi. i have a Porsche design cellphone and it has a problem. when i turn it on the car that appear in the screen is come and than the logo of Porsche design.every thing is normal now after that the screen...
It is possible that the hang up because there are error in the software.So to reset,remove the battery and the memory card from the phone using your PC scan the memory card for any corrup files or media files.It is possible when they are downloaded from unsafe sites.After the scanning,remove and format the card, copy only valid files to the card and do a scan before it is replaced.Now replace the card and battery and switch on the phone.If the phone is still hangs up or to slow when it is switched on.It is confirmed the the sofware has error and will need a reinstallation.
Sep 19, 2011 | Sagem Porsche P9521 Sim Free Mobile Phone
I am trying to figure out how to send music files over bluetooth. I can turn on my bluetooth, then turn on discoverability, but don't really know where to go from there. I connected with my friend's...
HTC G1 android does not come with file transfer over bluetooth. What you have to do is root your phone and download apps like blueX to transfer files thru bluetooth. hope this helps
Oct 23, 2010 | HTC G1
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
White screen of N 70
I have nokia N 70 when i switched it on it hangs appearing a white screen.please suggest some solution for it as soon as possible. Thanks
Jun 16, 2009 | Nokia N70 Cellular Phone
NOt turning on properly
Turn off the phone, take the battery off, than put it in again and turn on the phone. If in some case you can't turn off the phone, than take the battery off while the phone is on. If this doesn't help, contact your warranty provider.
Mar 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
(N6300)a white screen and NOKIA log-on
This might be due to virus or the software problem of your phone... Update it on net... First u have to download updating software from nokia official website or from other means... If this doesn't work just go to nokia care and tell him the problem... Good luck...
Dec 26, 2008 | Nokia 6300 Cellular Phone
I have a samsung D900 that has a problem where the bluetooth light is flashing red likes its trying to send / recieve but when i try and switch it off the phone just hangs and I have to turn it off then on...
i have a samsung D900 that has a problem where the bluetooth light is flashing red likes its trying to send / recieve but when i try and switch it off the phone just hangs and I have to turn it off then on again. I have tried re-setting factory settings with no joy. It means I...
please tell me how to fix it
Jun 30, 2008 | Samsung Cell Phones
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
