Question about JVC AV-48WP30 48" Rear Projection Television
Convergence picture looks like 3D movie without the 3D glasses. have tried using the remote control as users guide suggests. blue color will move up and down and to the side. red color will not move at all. cannot get them to come together
    Genius:
  • 1,554 Answers
Then it is likely the pre-amp transistor that controls the red is shorted out.
hopefully you have extended warranty.
there is a trick to likely get them aligned anyway if this is a tube tv.
Posted on Jan 26, 2008
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
My tv looks like it is in 3D without 3D glasses,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Top of the screen looks like its melting and the picture has double vision as if you were watching a 3d movie with no glasses
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 01, 2009 | Hitachi 65SWX20B 65" Rear Projection...
RGB lamps are not aligned
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
  • Screen looks 3D
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem?
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 14, 2009 | Sony KP-65WS510 65" Rear Projection...
Wide screen t.v. picture problem
Screen looks 3D
>>>Solution<<<<
Jan 05, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a sony wide screen projection t.v.(2003)...when i turn it on it looks like i'm watching a 3d movie without the glasses...the picture is also curved...any ideas?
Screen looks 3D
>>>Solution<<<<
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
91 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
