Panel board for ac unit
I have a switch that has a short on the heater part of the board. How can I get a replacement?
  • 26 Answers
Hi,You can get the replacement nearest Dimplex service center or try to see the web www.dimplex.com
Posted on Jan 12, 2008
6ya staff
SOURCE:
SHUTTING DOWN
Fixing unit protection circuit trouble
0101 When there is a short-circuit detection error in the halogen heater (ASIC detection)
Check the connection of the J114 jack of the AC driver PCB, and replace the AC driver PCB (triac short).
Replace the Pressure heater.
Replace the Fixing unit.
Replace the DC controller PCB 2 (MAISY).
Apr 15, 2014 | Canon irc5185i
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
CANNOT LOCATE FILTERS ON AC UNIT
Usually the filter is inside the heater housing. You remove the heater access door which should have a safety switch that opens when you remove the panel, thereby removing power from the electrical system on your unit. The filter, if there is one will be below the fan motor on an upflow heater.You should be able to see the filter when you open the heater access panel.
There should also be a filter in your return air duct or at the grille. The sizes of the filters are usually on the side of the filters.
If this helped you please take the time to write a short testimonial.
Aug 04, 2011 | Ruud UAKA018 Air Conditioner
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
We have a Weatherking Heater/AC unit the heater works and the AC worked last summer when we tried the furnace this winter no heat found out it was the 24 volt transformer replaced it and heat worked fine...
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Jun 28, 2010 | Heating & Cooling
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
Heater and AC run even though thermostat is off
It sounds like you have a short in the control unit at the ceiling pack. Remove the inner shroud from the AC and pull down the control unit. Remove the cover from the control unit to access the relays. With the thermostat off, check for power at the white (or orange depending on the unit) wire coming from the thermostat to the relay board. Also check power from the yellow and gray wires from the thermostat to the control board. None of these should be hot with the thermostat off. If there is power then you have a short in the wiring between the tstat and the upper unit. If there is no power, then you have a bad control board.
Hope this helps,
Jeff
Rate please!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
AC unit outside turns on but no air blows through the vents
Your indoor unit pc board is bad, replace it.
May 08, 2009 | Heating & Cooling
Blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
May 04, 2009 | Heating & Cooling
Replaced Fuse on Board. Unit keeps running
Sounds like crossed or shorted wire going to the thermostat. Disconnect the wire from the thermostat and see if it shuts off. If it does, it is the thermostat. Then disconnect either the white wire or red wire at the control board and see if the furnace shuts off. If it does, its the wiring. If it continues on, it is the control board. Remember you will need to tape the access panel door switch to the on position to be able to run the furnace with the panel off.
Nov 22, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
