Question about Whirlpool LSR6232J Top Load Washer
Won't agitate! Agitator doesn't agitate. When I open the washer while it's running, the agitator doesn't move at all. When I turn it with my hand while it's turned off, the top part spins but the bottom doesn't. Any suggestions?
My top load Ultimate Care II washer (from Lowes) would fill with water, but not agitate unless I banged lid really HARD. Half hour on phone, Whirlpool said it was bad lid switch, call a serviceman. One hour drive to appliance parts store, new lid switch for $18.17. Installed it. Same problem. Finally bent back the metal rod that extends from the left lid hinge under the lid (you can feel it easily under the rim of the tub) so the the switch, which is loose in it's slot, engages. It now works fine, and we have a spare lid switch we didn't even need! Lousy design, easy, FREE fix.
Posted on Sep 02, 2008
You should try to stop sticking the agitator up your *** so much =)
Posted on Apr 16, 2008
    Sergeant:
  • 351 Answers
Does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Posted on Mar 09, 2008
the dr
  • 447 Answers
SOURCE: whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Posted on Oct 01, 2007
  • 20 Answers
SOURCE: Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Posted on Jan 27, 2008
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: ge toploading washer will not agitate
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
Remove dual agitator
The agitator in your Maytag Dependable Care washer uses a back-and-forth motion to move your clothes from the top of the washtub to the bottom and back to the top again. The fins on the side of the agitator help facilitate this movement. When one of the fins sustains damage or the agitator fails to move, you must remove the agitator to make the necessary repairs.Disconnect your Maytag Dependable Care washer from the electrical wall outlet. Turn off the valves supplying water to the appliance.
2 Open the washer's lid to access the agitator. Look for a 1/4-inch hex screw recessed in an opening about three-quarters down the side of the agitator.
3 Insert a 1/4-inch nut driver into the opening in the side of the agitator. Fit the nut driver over the head of the screw. Turn the screw counterclockwise to remove it.Grab the bottom of the agitator with both hands. Pull the agitator from the bottom of the washtub.
  • Nut driver, 1/4-inch
Sep 29, 2016 | Washing Machines
Whirlpool top loading cloths washer agitator is loose when it should be turning. how do i tighten it?
Sounds like you might have bad agitator dogs. Remove the agitator cap, theres a 5/16th bolt that needs to be removed then the top of agitator comes off. The dogs are 4 little gears with teeth on them, when they get worn the top half of the agitator doesn't move.
May 09, 2011 | Washing Machines
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Hi i have a kenmore washer that makes a loud noise ,it goes though all of it cycles,but the white middle piece barly moves and it won't spin the basket on rinse or spin cycle.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 17, 2009 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Kenmore 90 series washer partially agitates
May 05, 2009 | Kenmore Washing Machines
Kenmore 70 series washer making humming sound and won't agitate
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Mar 04, 2009 | Kenmore Washing Machines
My washer is agitating very slowly
Feb 16, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not engaging
it will spin freely try to move it back and forth in full spins. if it spins both ways you need to replace the agitator dogs
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool LSR6232J Top Load Washer Logo
232 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
