Yes I have a ps3 controller and when I play Live on call of duty 4 when I want my man to run fast he wont sometime it works but other times he wont run when I push it can this problem be fix
does sony corporation fix this for free if so where do I go or mail it back to them for repaorsdoes sony corporation fix this for free if so where do I go or mail it back to them for repaors
I have a similar problem nothing to do with tiredness it is like a lack of response from the up direction on the left stick, sometimes when held part diagonally it works, anyone got a fix as just outside its years warrenty, I fear it is dead, good job I bought two when I got it ay!
You can't post conmments that contain an email address.
I dont mean to sound patronising,but your man can only run for a certain length of time....he needs to take a breather between runs,just like you would....
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
Some games will do this if you are holding the control-stick any direction while starting the system.
Next time you play it, try holding the stick just slightly in the opposite direction to compensate as you start the system, or unplug the controller-hold the stick down, then plug back in ( while playing )
If that doesn't work, it might be time for a new controller. Or you could open it ( disconnect first ) and check around the stick for anything that might be pushing it up.
GAMEPLAY CONTROLS Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships. X Button Select. Action. Triangle Button Cancel. Close Menu. Square Button Pan Camera (Hold) Circle Button Snap Camera to Sim L2 Button Sim Switcher Menu (Hold) L1 Button Freeze. Fast-Forward. R2 Button Toggle Walls On/Off R1 Button Freeze. Fast-Forward. Start Button Pause Select Button Toggle Control Mode Left analog stick (L3 Button when pressed down) Move Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS X Button Place or Grab Object Triangle Button Cancel. Back. Square Button Remove Object and Put In Inventory Circle Button Toggle Blueprint Mode L2 Button Clone L1 Button Rotate R2 Button Undo/Redo R1 Button Rotate
BUILD/REMOVE MODE CONTROLS X Button Place/Remove Wall, Wallpaper, or Floor Triangle Button Cancel. Back. Square Button Pan Camera Circle Button Toggle Blueprint Mode L2 Button Clone Wallpaper or Floor R2 Button Undo/Redo Combo #1 L1 Button or R1 Button + X = Build or Fill Room Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
Playstation3 needs reliable, stable, and quite fast internet connection. Check with your internet service provider to get better speeds and this will solve your online gaming problems
Have you found a solution to this problem? I have the same issue for the right stick. I played the SKATE demo a couple of times and that exaxt thing happened to me. Help please.
