Question about Hitachi 53UDX10B 53" Rear Projection Television
Screen seems really red at times and left side missing several inches of display
The IC's were recently replaced. Now faces seem really red and reds seem almost purple or orange at times. A small portion of the bottom of the picture and several inches of the left side are not fitting on the screen. What could be causing this?
    President:
  • 4,402 Answers
Red gun level is too high..
Posted on Jan 24, 2008
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
About 6 inches from the left side of tv there is a red shadow to pepole or writing. when cold the problem is not there. seems as it warm up the worse it gets?
you need to have the stk 392-120 replace but some restor 2.8onm to this will fix red line it a coming thing for this set if a game xbox or ps2 or 3 or eny games will miss up the bigscreen bad to
Dec 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Steady red light on black berry 8800
My blackberry does not show any thing on screen just white screen display
Apr 29, 2009 | RIM BlackBerry Bold 9000 Smartphone
Convergence STK ic parts?
Yes your set uses two STK392-110 convergence ICs you can get replacment ICs at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Aug 06, 2008 | Toshiba 57H82 57" Rear Projection...
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Mar 23, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
