Question about Fuji FinePix F20 Digital Camera
Battery Chargeing Hi, will connecting my Camra up to the Computer charge the battery??
  • 667 Answers
I'm sorry, it will not. You will need to use the ac adapter to charge the battery. Here is Fuji's link to all about your F20:
http://www.fujifilmusa.com/JSP/
fuji/epartners/ServiceSupportProduct.jsp?prodcat=856005
Posted on Jan 12, 2008
6ya staff
SOURCE:
Battery light on
Alternator is not charging, if you got a reman it should be under warranty and if a shop put it in they should be able to test for free
Apr 04, 2015 | Cars & Trucks
Sony vaio battery went dead n now won't startup normally
Does your battery not start the computer up at all or it starts the computer up but something is wrong with the battery
Example the battery only charges to 80% then stops chargeing?
battery just can hold a charge at all etc.
Mar 17, 2013 | Computers & Internet
Hi have a diamecDMU12-7.6(12v7.6AH/20HR) When i plug it in the light stays on green all the time. Is it sill chargeing
check under the blue plastic cover of the battery and make sure that the positive and negatove terminals are connected
Jun 13, 2011 | Peg Perego 12 Volt Rechargeable Battery
Meaning of red battery light on dash
Hello Mdeon.
The red light is indicating that the alternator is not correctly charging or not charging at all.
Basic check would be to verify that the drive belt is actually turning the alternator. A loose belt can do this.
If the belt is OK, then check the connections at the alternator for looseness or corrosion.
Check the main terminal at the alternator for 12.5 volts ignition key off.
Make sure the mounting bolts for the alternator are clean and tight.
If all that checks out, replace the alternator, it is defective.
Thank you for using FixYa.
KL
Jan 09, 2011 | Ford F-250 Cars & Trucks
Wont start get clicking
Please see my tip at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Dec 24, 2010 | 2003 Saturn ION
Its turns on beeps then shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare M1033 - black Digital...
When I have phone on chrger, the red charger lite comes on, says it's chargeing but it is not chargeing, I still have only 2 bars after an 12 hr. charge!
Try some of the following / revert in case you have already for futher assistance ;
1.) Try connecting it with your PC & see if the phone picks up some charge.
2.) Try testing the phone with another battery (You can grab it from your friend to test.).
3.) It can also be the power supply, can't just move that option out without testing it.
Let us know for any future assistance.
Thanks
Fame !
Jul 13, 2009 | Motorola Mobility RAZR V3
Short
Tour problem is in the voltage regulator inside the alt.
Replace the alt.
Oct 24, 2008 | 1993 Jeep Grand Cherokee
Camra not charging battery & nither detected by computer
sounds like you have either a loose or not fitted correctly strip connector.possibly when opened for repair was not put back together properly.
May 23, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Fuji FinePix F20 Digital Camera Logo
141 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
