Question about Philips DVP5982
No sound I have a DVP5982 and recently it stopped playing any audio on my HDTV. I have tried switching to a new HDMI port and playing with the audio settings but nothing has worked.
  • 3 more comments
  • lhennig Jan 22, 2008
    I have sort of the same problem. I connected the player to an AKAI LCD TV via HDMI and once in a while I had to go to the DVD-digital audio setup and set the HDMI -Audio to "On". Now even this doesn't work anymore - there's just no audio when playing DVDs. Please help?
  • skulikov Apr 05, 2008
    This is my second DVP5982 and both had the same problem after about a month or two HDMI audio stopped working. Sometimes I had to enable HDMI Audio in Setup, but now it is dead. Other outputs function correct.
    Solution will be appreciated.
  • DittoTwo May 12, 2008
    The DVD player (new Dec 2007) worked great at first. Then, the audio stopped while everything else seems to be fine. I've gone into setup and tried to solve the problem by resetting the HMDI to ON. This does not solve the problem. It is frustrating to not be able to solve this problem. It seems that others have the same problem, and no solution is offered yet. Please help!
  • Anonymous May 17, 2008
    I bought this played for like 3-4 months, now suddenly no sound is out. This product is a ****.
  • jvijayakar May 22, 2008
    I am trying to play my regular DVDs on this player, but I am not getting any Audio output from this. I am using PHilips HDMI cables. I have not tried it out with component output.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
The Philips DVP5982 has an odd menu setup for the HDMI sound.
If you get sound from the analog outputs from the unit, but no sound when you use the HDMI output, use this procedure to see if you can restore it:
On the remote control, press Setup.
- Right cursor to the Audio Setup Page
- Go down to Digital Audio Setup
-Right cursor, to get to the screen that shows
Digital Output
LPCM Output
HDMI Audio Setup
Try to go up to the Digital Output setting- if you can't , and instead it shows only HDMI Audio Setup with the "On" highlighted in blue, this is the quirk:
Go into the HDMI Audio Setup, and select "Off", and press Enter, so it's highlighted in blue.
Now it should let you go into the Digital Output menu selection, where you may find it to be on the "Off" setting.
Select "All", and then you can go back to the HDMI Audio Setup and set it to On again, and it should now output sound from the HDMI again.
For some reason, they decided to lock out the Digital Output settings menu when the HDMI Audio is On- go figure.
So you need to turn off the HDMI sound before you turn the sound on.. ;)
Posted on Sep 24, 2010
    Problem Solver:
  • 7 Answers
I had this problem on my pc, it turned out to be a driver conflict between mobo and graphics card. i uninstalled both drivers and reinstalled nvidia drivers and i finally have sound via hdmi.
Posted on Dec 11, 2012
I had the same problem, downloaded the latest firmware from Philips web site and the sound came back. So, just try to upgrade your player's firmware. Make sure you follow all steps described by Philips during upgrade.
Posted on Jul 13, 2008
No sound
Here is a possible solution to this problem, assuming the DVP5982 is connected to the tv with an HDMI cable.
Press setup on the remote control of your DVP.
· Go to the Audio Setup icon with the right arrow button
· Press the down arrow button to select DIGITAL AUDIO SETUP and press the right arrow button.
· Go to DIGITAL OUTPUT with the cursor buttons and press the right arrow button.
· Go to PCM ONLY with the down arrow button and press OK to confirm
· Press setup to leave the menu.
The DVP5982 will now send analogue stereo audio to the tv.
Feb 11, 2008 | Philips HTS3450 System
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Oct 04, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips DVP5982 Logo
693 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
