Question about Toshiba Satellite M35X-S111 Notebook
Video issue My screen went dark blue. I restarted the machine and I am getting white vertical lines on the screen. I plugged it into an external LCD monitor and I am getting the same results. Can you offer some suggestions?
  • 20 Answers
You should reinstall your graphics card or video card
Posted on Jan 12, 2008
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have a COMPAQ CQ60-420US NB PC. Last few months some webpages would 'jiggle', I chalked it up to slow servers. However... yesterday the screen went white. I turned on the laptop, the drive and...
I would plug it into external monitor. it if works good on the monitor. could be bad video cable or lcd panel. video cables get pinched in the hinge or lcd get broken due to lack of support around the screen (poor design)
Jun 20, 2017 | Compaq Presario CQ60-204NR Notebook
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
Vertical lines on lcd how can i fix it works perfect with ext monitor and i did bios update and it help some?
Restart the Computer and access the BIOS and check if the vertical lines are visible. If the vertical lines are visible in the BIOS then the issue is with the LCD screen itself and may require service. This is confirmed when an external monitor works fine. If the issue is related to the video card of the Computer then the lines should also appear on the external monitor which is not the case.
Oct 24, 2009 | Dell Latitude C600 Lcd LCD Display
Bottom half of laptop is dark with vertical lines
Generally, what you describe is a failure of the LCD screen.
Things you can try:
1. Reseat the LCD video connection to the video card.
2. Connect an external monitor see if the issue occurs externally (If so the video card is failing)
If video works normally externally, then LCD replacement is warranted
If the system is in warranty, contact technical support from the manufacturer.
Feb 02, 2009 | Computers & Internet
Vertical lines in my laptop screen
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
Sep 29, 2008 | Computers & Internet
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
Sep 19, 2008 | Dell Inspiron 1501 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
