Question about Acer Aspire 1414 Notebook
Acer Blinks orange but doesnt work
My laptop , blink and orange but when i put my ac adpter , i doesnt responde it keeps on blinking orange , then after a couple of minutes trying it turn on then 2 minutes later is off again
  • anitaagua14 Jan 24, 2008
    the right answer is take away the ram and the put it back
  • 20 Answers
You should reinstall your graphics or video card
otherwise you have to change your graphics card
Posted on Jan 12, 2008
The orange light blinks a couple of times then goes off and after that the green power light blinks once with the antenna light
Blinking orange lights means no power or low power. Not enough to power the laptop. If it is plugged in and still the same, then your charging port or charger is damaged.
Mar 03, 2014 | Acer Aspire 5050-3371 Notebook
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
It doesnt turn on but when i plug the adaptor charger the orange light blinks. but theres no display on the screen
I need to know how this thing behaves:
unplug the laptop from your ac adapter. remove battery. plug in your ac adapter - now the power LED should show a green. now if you turn it on, and the power LED blinks orange (amber) - you have a bad motherboard.
these are older units (the 4300's are 600mhz, 650mhz, and 700mhz for 12", 14", AND 15" screens, respectively). Your best bet is to buy something comparable on eBay, and do the swap yourself. These systems (and motherboards) have been spectacularly reliable, and used, incomplete systems are practically being given away on eBay for a pittance... That's how I'd approach it.
Nov 16, 2010 | Toshiba Satellite Pro 4300 PC Notebook
Hi, I have Acer extensa 5220 ,it is 1.5 years old...Recently a problem started that when i connect battery to my laptop(AC plug is on) the battery LED on the laptop blinks 3 times orange and turn into...
Borrow a "MultiMeter" and check the VOLTAGE and AMPERAGE output from the battery. Although it's rare for an 18-month-old battery to "die" (or to refuse to recharge), it can happen.
If you try to run the computer _only_ on the battery, without AC power, does it work? If not, replace the battery -- look on eBay for cheaper-than-Original-Equipment replacement batteries.
Aug 02, 2010 | Acer Extensa 5620 Notebook PC
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Battery light blinks on Acer 3680 but won't boot
yes you have a problem inside your laptop.find the slot of memory then remove easy the memory then make a clean the memory then put it back again and try to but the unit.thats all...good luck and i hope its done..thanks
Jan 09, 2010 | Acer Aspire 3680 Laptop
Battery status LED blinkings amber
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Jan 25, 2009 | Acer TravelMate 3260-4874 Notebook
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Nov 01, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 1414 Notebook Logo
256 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
