Question about Sub-Zero 695/O Side by Side Refrigerator
Water/Ice Dispenser Does Not Consistently Work
Our ice maker/water dispenser does not consistently work. At times when you hit either the ice or water dispenser button on the door, the lights simply blink and nothing happens. If I open the door and press the unit on/off button, this usually solves the problem. Any suggestions on a more permanent fix?
  • 1 more comment
  • BETC1060 Apr 06, 2009
    I bought my SubZero 695 in May 2005...have had several problems...one of which being I had to disconnect my under the sink reverse osmosis system to get the icemaker to work. Now that I have total house R/O it works for the most part, but a few times a week, I get an ice cube that gets stuck and won't "dump" and thus prevents further ice from being made (you don't realize you have a problem until you've completely run out of ice). I also have the problem of every now & again not being able to dispense water. No rhyme or reason to it. Have not been very happy with my refrig overall as you expect to have no problems for a long time with a unit as expensive and a "Quality" name brand.
  • Anonymous May 17, 2009
    My ice and water in the door no longer work on my side by side Sub Zero. I can only get the ice from bulk ice inside the fridge. Has anyone out there figured this problem out?
  • Jjzh Jul 23, 2013
    Is there any solution discovered on this topic? I got this issue today, no water unless I turned the unit on/off button. But the "fix" does not last long, after some minutes, it fails again.
I am buying a 695. The sales person told me that my current
reverse osmosis water system will cause the ice maker to fail.
Im trying to find more out.
Posted on Feb 08, 2008
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Posted on Jan 13, 2008
Thanks,
Sandra
Posted on Jan 09, 2009
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Sub-Zero 695/O Side by Side Refrigerator Logo
944 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
