Question about Samsung HCM4215W 42" Rear Projection Television
Need blue CRT for HCM4215W. Anybody got one for sale? Please help.
I am looking for a blue CRT my bulb cracked in half. If you have one you want to get rid of, please contact me. I might even purchase the whole set.
Thanks to all.
VT
Ihave one call 949 566 5338 ask for tony
Posted on Apr 18, 2009
  • jas_kiu Apr 18, 2009
    i have one
I have the HCM4215W and am getting rid of it and it is yours for $225, im in cincinnati.
Posted on Oct 14, 2008
I live in Orlando FL, my HCM4215W tv works great.. but moving and want to sell it... if your local, its $250 for it... iec123@hotmail.com.
Posted on Jun 29, 2008
Light blinks there is sound but no picture
We have a Samsung DLTV that does this when the bulb needs to be replaced. We have to replace the bulb quite frequently. You can look up the bulb you need online using the model number of your TV. I hope this helps.
Sep 14, 2011 | Samsung HCM4215W 42" Rear Projection...
I have the back off looks like 3 bulbs. True or false
Not bulbs, but 3 CRT tubes is what you are seeing rear projection TV's don't use bulbs onlly DLP projection uses a bulb as a light source....
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HCM4215W 42" Rear Projection...
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Blue "shadows" on my picture?
if you take the front bottom panel off, you will see 6 little nobs, look like this ::: the midle 2 should be blue, middle top is the focus, middle botton is intencity, turn the middle bottom nob down about a quarter to half turn, should solve prob
Jan 08, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
easyab
Jul 28, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
CRT question
You need the right tube. As for one for sale, you may find one here if some of the other questionaires don't get their sets fixed. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 21, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W pink/green and wavy
Practice visual acuity technique!Check signal PCB for CRT coolant leak.Cleaning circuit board may restore normal operation,but one or more leaks will cause problems to re-occur.Change leaky CRT(s).
Dec 19, 2006 | Samsung HCM4215W 42" Rear Projection...
Green ctr
Locate the screen drive controls, usually under the back panel above the main board, attached to the frame. There should be an adjustment for each color. Note the position of the green screen drive. Turn up the drive and see what happens. If you now have green your drive just needed adjusted. If nothing changes then you should remove the green crt board from the crt and replace it with either the blue or red crt board. If the crt displays an image the problem is in the green drive circuitry. If there is no picture you probably have a defective green crt. Usually it is not worth replacing the crt due to cost, etc. If you have the skills to perform these diagnostics good luck and remember safety. If not you will need to find a tech or shop to do it.
Jul 02, 2006 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
