Question about Nokia N95 Cellular Phone
Nokia n95 calender
Hi, have purchased n95 and am happy overall but cannot get calender to work just shows empty boxes with week number down side and days across top. cannot access options or use at all.
  • teresa foster Jan 13, 2008
    hi, thanks for trying but the problem is that i cant access options to change the view or add notes or do anything at all with the calender.
    the screen with the calender comes up ok but thats it. the options button doesnt work all you can do once there is exit.
  • teresa foster Jan 14, 2008
    hi, found out what the problem was. i had sychronized my old nokia 9500 communicator calender entries with my new N95 phone and it had upset the whole thing. Fixed it eventually by reinstalling all the software. annoying but it worked. Thanks for trying to help.
mind there are different views in the calender, view by week, by months etc...Make sure you're at the right view to edit it.
For instance, you cannot say "I have a rendez-vous on week 2".
That's why in week view you can not add a meeting. For editing, try to get in day view.
Otherwise, you have an enhanced version of epocware handy calender.
Hope this helps.
Posted on Jan 12, 2008
  • Anonymous Jan 13, 2008
    OK,
    did you try to restore factory settings ?
    Try this:
    Menu > Tools > Settings > General > Factory settings
    Note that all you personnal settings will be lost !
    (But it not a big issue to reset your personal config)
6ya staff
SOURCE:
My nokia n95, screen just lights up & makes noise. u can call & recieve calls but nothing on screen except white back ground???I down loaded new face book has been updated & loaded google....
Hi you will need to replace the flex cable running from your main board to the screen, if this does not work then it is a Software issue and will need to be flashed with latest firmware, good luck
Aug 22, 2011 | Nokia N95 Smartphone
I have nokia n95 with 2 gb memory card whenever i try to download any application i got message "phone memory full" please delete some data.But i have checked memory status it shows memory in...
Write your phonebok to the paper & other important information, Then try to delete it all jus to free your memory (empty) or REFORMAT, then you may return to download, or delete only the unnecessary videos, image, mesgs. & unused program that you download, Then download skype & other important program to your cellular, Note: always check your memory content, Always have an free allowance to download in your memory at least 50 to 25 percent free.
May 26, 2011 | Nokia N95 Cellular Phone
How do i install a charging port on mt nokia N95 mobile phone?
Go to ctrl panal--> internet option a dalog box apear clk on connection then 3 option will come side right side of a writting box ADD NEW click on it aftr dat make a dial-up-connection via bluetooth a number ask type *99***1# set all suitable port and set default aply ok aftr dat goto start button--> connect to internet--> dial-up-connection down number ask type *99***1# then dial via bluetooth Thank you
Apr 01, 2010 | Cell Phones
N95 RESTART AND RESTART AND STOP FUNCTION
Try the following manual method to hard reset/format Nokia N95:
1) Turn off the mobile device.
2) Turn on the phone and quickly Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button. keep holding the keys untill the mobile phone restarts and prompts you to enter details time and country.
Warning: Make sure the battery is at least 25% capacity so the phone will not power down during hard reset. ( Hard reset normally takes about 2 minutes only).
Warning: Hard reset will format everythings in your phone ( Your contact, calender, photos, installed Apps, Etc.) and the phone will be returned to its original state as if it was purchaced new.
( Mini memory card MMC) will not be effected :)
Dec 06, 2008 | Nokia N95 Cellular Phone
My n95
Vibrate must be enabled for the profile you are in. You can change profiles by pushing the power button and not holding it down. As far as touch screens go, the Nokia N95 does not come with a touch screen on any version, if you had this capability then you must have a different phone or a fake N95. Hope this helps! Happy Hollidays!
-Joshua Childs
Sep 11, 2008 | Nokia N95 Cellular Phone
Nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
Nokia N95 8Gb
hi i will give you your master code but it wont work if you have entered the wrong number more than 5 times if you have then you need to purchase flash lead and unlocking software and equipment witch would cost more than a new phone.
This code only works with that imei number ok
your master code is 0246041706
Let me know if you need further assistance ok
Sorry its been a while but been away from home for few days ok
Mar 28, 2008 | Nokia N95 Cellular Phone
Nokia n95 problem
The connection might have worked loose. The problem is, with the Nokia N95 a number of parts have to be renewed when dismantling, including screws.
Mar 04, 2008 | Nokia N95 Cellular Phone
Unlocking code for nokia n95 8gb on (3G uk)
You can unlock it, but your contract will not go away. If you signed on the dotted line for 18 months or whatever, then that is when the contract will end.
Type *#06# to displays the International Mobile Equipment Identity (IMEI) number, that's the number required to unlock your phone. However your service provider could BLOCK it permanently.
Feb 27, 2008 | Nokia N95 Cellular Phone
Help my n95 phone is sick
Best thing to do is to first sync your device with Nokia Pc Suite and Outlook so you dont lose all your calandar information. Then either go to your local Nokia service center and have your device flashed. It will be as good as new. I believe Nokia also allows you upgrade your own firmware as well through thier web site. Look on the Nokia site for thier "software update" . If all fails, look in my profile, and im sure we can help you out.
Jan 24, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
128 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
