Question about Maytag SDE2606 Electric Dryer
Will not turn on at all, is getting power.
How do you remove the fuse?
    Sniper:
  • 65 Answers
Open access panel and the thermal fuse is located on the heater box in the rear left corner on the back wall the part number is 37001139 retail price 48.00 comes as complete assy with operating therm and element. if this thermal fuse blew please check for vent restriction or restriction under lint screen.
Posted on Feb 16, 2008
How do I get the radio to turn off????
my guess is someone has installed an aftermarket radio?
your yellow and red wires are backwards on the back of the stereo. you've got constant 12v power going to the ignition/memory wire on the stereo.
Oct 11, 2014 | 1996 Ford Explorer
WE HAD A LIGHTING STORM AND I HAVE NO LIGHTS ON MY BRAVIA WILL NOT TURN ON IS THERE A BREAKER OR FUSE TO LOOK FOR
There is a fuse in the tv power supply board,a fuse it is located near the a/c socket plug in of the tv power supply board.Lighting storm pack a huge anount of power and magnatic static field.If ur tv was in that path.U will not fixed it with a new fuse the tv whole power board probally dead already and those other circuit boards on the tv might be dead too.Good look with the replacement of the fuse,maricles might happen ur tv just have a dead fuse only.Not must take to or call many tvs shops and get the best estamates prices to fixed the tv.Not a do it self project,if tv a got hit by a massive power surges.
Aug 11, 2011 | Sony BRAVIA KDL-46V3000 Television
Turn signals and brake lights won't function
GET A GOOD FUSE TESTER, TEST EACH FUSE. THERE ARE 2 FUSEBOXES. ONE UNDER THE HOOD & ONE IN THE DASH. ALL FUSES CAN BE TESTED WHILE STILL IN PLACE. THERE ARE TEST POINTS FACING OUT. TURN ON IGNITION SWITCH FOR THIS TEST. POWER ON 1 SIDE, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
IF ALL FUSES RELATED TO THIS PROBLEM TEST OK, CHECK OR REPLACE THE TURN/SIGNAL/HAZARD FLASHER, { LOCATED UNDER DASH, NEAR STEERING COLUMN, PROBABLY SQUARE & BLACK. IF THAT'S OK, IT WILL HAVE TO BE THE TURN SIGNAL/ HAZARD SWITCH. ALSO CALLED COMBINATION SWITCH. REMOVE THE PLASTIC HOUSING AROUND THE STEERING COLUMN UNDER THE STEERING WHEEL. IT LOOKS LIKE THE AIRBAG & A LOT OF SPECIALIZED TOOLS WILL BE NEEDED. YOU MAY HAVE TO EMPLOY A RELIABLE SHOP IF THE COMBINATION SWITCH IS THE PROBLEM
Jan 10, 2011 | 1996 Chevrolet Cavalier
How do I Turn it on
The power switch is on the left side of the machine near the back of the machine.
Assuming that you found the power switch, if nothing happens when you flip the power switch, chances are that you have a blown fuse.
1. First be sure that you unplug the machine!
2. Remove the "Platen" (the big black roller that the paper wraps around) there are clips on both side of the roller. NOTE Which side of te platen has the gear, this will be important when you reassemble it.
3. Turn the machine over and remove the 4 screws in the bottom.
4. Turn it over again and remove the top
5. The fuse is located in the power supply (where the power cord goes in the machine)
6. Replace the fuse with one of the same rating. Fuses can be bought at electronic supply stores (like Radio Shack) or at some hardware stores. Take the fuse with you to be sure that you get the same size physically and that it is rated the same as the old one.
7. Reassemble the machine be reversing the procedure.
Dec 17, 2010 | Brother ML-300 Typewriter
Have a 89 dodge raider;;have no turn//4-way flashers or brake lights;;all fuses good;have power to brake light switch and leaves switch when apply brakes;;found round flasher[4 way flasher]know this...
Hey HotrodHarley,
I would pull out your hazzard switch and clean it real well. the signal, brake lights are connected to the hazzard switch and if it doesn't fully disengage you wont get the brake lights or the flashers to come on. It happened to me on my 89 Raider last year.
Oct 27, 2010 | 1987 Dodge Raider
I have kenmore front load dryer. wont do anything when you turn it on. was working fine then just stopped. is getting power. what could cause this?
check thermal fuse located in back panel. make sure power is unplugged before removing cover. thermal fuse is located near exhaust and it's coated with white plastic with 2 leads sticking out. with volt meter check for continuity, no continuity must replace thermal fuse, it cannot be reset.p.s. remove wires from fuse to get accurate reading.
rwpfn@aol.com
Sep 01, 2010 | Kenmore 63942 Dryer
I turned down the volume on my kdc-mp522, when i went to turn it back up, it was off (I did not stop or turn car off.). I cannot get it to power on, i can insert and remove disc, so there must be power,...
that is kind of strange and if your getting power to put a cd in but no for it to fully power the unit you may need to check another fuse it will be not be your radio fuse but instead a mini fuse in your vehicles cabin should be on the left side under neith the dash or on the side of the dash it will most likely be a 10 or 15 amp mini fuse that supplies power from the fuse box to the reiceivers acc source ignitions source
Nov 11, 2009 | Kenwood Sirius KDC-MP522 CD Player
Panasonic TH-42PX600U plasma TV. No power at all. Where is the fuse (if any)?
I'm having the exact same problem. My Panasonic 42 inch TH-42PX60U just turned off while I was watching TV. I removed the fuses (both were blown) and replaced them and am now getting the red light that blinks ten times.
What should I do now???
Thanks!
Abbie
abbie.bejrowski@gmail.com
Nov 10, 2008 | Televison & Video
Fuse
A schematic can be obtained on the internet or localy through a dealer channel.
As for your first question.
A glass fuse is a device which allows only a certan amount of power to flow through it.
it's a glass tube about 1 inch long and with a little wire of aluminum running through it and a aluminum metal cap on each end with the voltage and amps written on at least one end.
A fuse of this type sits in a tray that has two metal ends to hold the fuse in place.
Some of them are coated and light tan in color ( could be to prevent shattering )
Once the power level is exceeded the fuse gets too hot and burns up the filiment causing
an open circuit and stopping power flow.
A fuse of this type can be removed from it's try by using insulated gloves or
an insulated fuse removal tool to prevent shock and be replaced by an identical fuse
with the exact same voltate and current rating.
Once the fuse is removed from it's tray it can be tested with an Ohms meter
to determine if the fuse is actually open.
a glass type fuse in a television set will be located near the power chord
connection to the chasis ( main board )
A blown fuse is a sign that a power surge occured
1. If the power surge occured from getting too much power from the power cable side that plugs into
the wall thats good because chances are it just blew a fuse because of it.
2. If the power surge was the result of failure of a component deeper into the circuitboard replacing the fuse will not do any good and may blow again as soon as you turn on the power.
Shalom..
Sep 15, 2008 | Televison & Video
Audiovox AVT2540 won't turn on
The only possible check that could be done without removing/opening the Audiovox TV would be to check for the presence/absence of supply power/voltage depending on how the TV is powered (12VDC or 120 VAC). Normally, there would be an fuse and/or circuit breakers.for the RV's entertainment system including the TV.
The 120-volt circuit breakers and 12-volt fuses are located in the same compartment. These devices interrupt the power if the circuit is overloaded.The 120-volt circuit breakers include a 30 amp main breaker and several smaller breakers for individual circuits. If a circuit breaker is tripped, look for an overload on the circuit, then reset it by turning the breaker OFF and then turning it ON. Do not try to reset a breaker the second time without locating the overload problem. The 12-volt fuses protect individual circuits. If the circuit is overloaded, it will blow the fuse and the fuse must be replaced. Check the circuit for an overload and replace the fuse with the same type or amperage rating.
If the above checks out, then problem is internal to the unit and would require removal from its current position.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Televison & Video
Maytag SDE2606 Electric Dryer Logo
46 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
